The euclidean traveling salesman problem is NP-complete, Theoretical Computer Science, vol.4, issue.3, pp.237-244, 1977. ,
DOI : 10.1016/0304-3975(77)90012-3
URL : https://doi.org/10.1016/0304-3975(77)90012-3
Computers and Intractability: A Guide to the Theoryof NP-Completeness, 1979. ,
Traveling Salesman Problem: An Overview of Applications, Formulations, and Solution Approaches, pp.1-24, 2010. ,
Human Performance on the Traveling Salesman and Related Problems: A Review, The Journal of Problem Solving, vol.3, issue.2, 2011. ,
A two-commodity network flow approach to the traveling salesman problem, Congressus Numerantium, vol.41, pp.167-178, 1984. ,
A dynamic programming approach to sequencing problems, Journal of the Society for Industrial and Applied Mathematics, vol.10, issue.1, pp.196-210, 1962. ,
A cutting plane procedure for the travelling salesman problem on road networks, European Journal of Operational Research, vol.21, issue.3, pp.307-317, 1985. ,
The traveling salesman problem: A survey, Operations Research, vol.16, issue.3, pp.538-558, 1968. ,
An analysis of several heuristics for the traveling salesman problem, SIAM Journal on Computing, vol.6, issue.3, pp.563-581, 1977. ,
A method for solving traveling-salesman problems, Operations Research, vol.6, issue.6, pp.791-812, 1958. ,
Computer solutions of the travelling salesman problem, Bell Systems Technical Journal, vol.44, issue.10, pp.2245-2269, 1965. ,
W: An effective heuristic algorithm for the traveling salesman problem, Operations Research, vol.21, issue.2, pp.498-516, 1973. ,
An introduction to variable neighborhood search, Meta-Heuristics: Advances and Trends in Local Search Paradigms for Optimization, pp.433-458, 1999. ,
DOI : 10.1007/978-1-4615-5775-3_30
Variable neighborhood search: principles and applications, European Journal of Operational Research, vol.130, issue.3, pp.449-467, 2001. ,
DOI : 10.1016/s0377-2217(00)00100-4
Improving variable neighborhood search to solve the traveling salesman problem, Applied Soft Computing, vol.68, pp.83-91, 2018. ,
DOI : 10.1016/j.asoc.2018.03.048
Optimization by simulated annealing, New Series, vol.220, issue.4598, pp.671-680, 1983. ,
A genetic algorithm tutorial, Statistics and Computing, vol.4, issue.2, pp.65-85, 1994. ,
DOI : 10.1007/bf00175354
URL : http://www.cs.uga.edu/~potter/CompIntell/ga_tutorial.pdf
An Improved Genetic Algorithm with Decision Function for Solving Travelling Salesman Problem. Proceeding of 12th ISKE, pp.1-7, 2017. ,
DOI : 10.1109/iske.2017.8258774
Distributed Optimization by Ant Colonies, Proceedings of European Conference on Artificial Life, pp.134-142, 1991. ,
Pheromone Model Selection in Ant Colony Optimization for the Travelling Salesman Problem, Chinese Journal of Electronics, vol.26, issue.2, pp.223-229, 2017. ,
An Improved Routing Optimization Algorithm Based on Travelling Salesman Problem for Social Networks. Autonomous and Sustainable Computing for preparing the Internet of, Things Environment, vol.9, issue.6, p.985, 2017. ,
Modified Ant Colony Optimization with Pheromone Mutation for Travelling Salesman Problem. Proceeding of 14th ECTI-CON, pp.411-414, 2017. ,
Symbiotic Organisms Search: A new metaheuristic optimization algorithm, Computers and Structures, vol.139, pp.98-112, 2014. ,
Discrete symbiotic organisms search algorithm for travelling salesman problem, Expert Systems With Applications, vol.87, pp.70-78, 2017. ,
Simulated annealing based symbiotic organisms search optimization algorithm for traveling salesman problem, Expert Systems With Applications, vol.77, issue.1, pp.189-210, 2017. ,
Solving large batches of travelling salesman problems with parallel and distributed computing, Computers and Operations Research, vol.85, pp.87-96, 2017. ,
, Probe Machine. IEEE transations on neural networks and learning systems, vol.27, pp.1405-1416, 2016.
