Language Understanding of the Three Groups of Connections: Management Innovation Dynamic Mechanism and Intelligent Driving Environment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
The purpose of this paper is to show how to improve people’s understanding of the dynamics of management innovation and intelligent drive environment. The method is as follows: First, through the intelligent text analysis, refine the essence of management innovation dynamic mechanism and intelligent driving environment. Then, it expounds the progress of research on the dynamic mechanism of management innovation. Finally, it discusses the construction of intelligent driving environment, and takes “physical, transaction, insight” and its application scenarios as examples. The result is: not only the research on the dynamic mechanism of management innovation and the concise expression of the construction of intelligent driving environment, that is, the result of intelligent text analysis. The significance lies in: from the perspective of the three kinds of connections: “physical, transactional, and epiphany”, it gives a more accurate language understanding paradigm for both the management innovation dynamic mechanism and the intelligent driving environment.
474230_1_En_25_Chapter.pdf (510.7 Ko) Télécharger le fichier
hal-02118836 , version 1 (03-05-2019)
Paternité
Guangsheng Wang, Hanglin Pan, Xiaohui Zou. Language Understanding of the Three Groups of Connections: Management Innovation Dynamic Mechanism and Intelligent Driving Environment. 2nd International Conference on Intelligence Science (ICIS), Nov 2018, Beijing, China. pp.235-242, ⟨10.1007/978-3-030-01313-4_25⟩. ⟨hal-02118836⟩
29 Consultations
24 Téléchargements
