A Review on Basic Data-Driven Approaches for Industrial Process Monitoring ,
, IEEE Transactions on Industrial Electronics, issue.11, pp.6418-6428, 2014.
Perspectives on process monitoring of industrial systems ,
, Annual Reviews in Control, vol.48, issue.21, pp.931-939, 2016.
From Model, Signal to Knowledge: A Data-Driven Perspective of Fault Detection and Diagnosis ,
, IEEE Transactions on Industrial Informatics, vol.9, issue.4, pp.2226-2238, 2013.
Quality-related prediction and monitoring of multi-mode processes using multiple PLS with application to an industrial hot strip mill ,
, Neurocomputing, vol.168, issue.C, pp.1094-1103, 2015.
Application of Clustering Methods for Online Tool Condition Monitoring and Fault Diagnosis in High-Speed Milling Processes, IEEE Systems Journal, vol.10, issue.2, pp.721-732, 2017. ,
Decentralized Fault Diagnosis of Large-Scale Processes Using Multiblock Kernel Partial Least Squares, IEEE Transactions on Industrial Informatics, vol.6, issue.1, pp.3-10, 2010. ,
A Review of Data Driven-based Incipient Fault Diagnosis ,
, Acta Automatica Sinica, vol.42, issue.9, pp.1285-1299, 2016.
Data-Based Techniques Focused on Modern Industry: An Overview, IEEE Transactions on Industrial Electronics, vol.62, issue.1, pp.657-667, 2015. ,
Recent advances on SVM based fault diagnosis and process monitoring in complicated industrial processes ,
, Neurocomputing, vol.174, pp.643-650, 2016.
Fault Diagnosis in Internal Combustion Engines Using Extension Neural Network ,
, IEEE Transactions on Industrial Electronics, vol.61, issue.3, pp.1434-1443, 2013.
Bayesian Networks in Fault Diagnosis ,
, IEEE Transactions on Industrial Informatics, issue.99, pp.1-1, 2017.
A comprehensive comparative study of DGA based transformer fault diagnosis using fuzzy logic and ANFIS models ,
, IEEE Transactions on Dielectrics & Electrical Insulation, vol.22, issue.1, pp.590-596, 2015.
Rolling bearing fault diagnosis using an optimization deep belief network, Measurement Science & Technology, issue.11, p.26, 2015. ,
A sparse auto-encoder-based deep neural network approach for induction motor faults classification, Measurement, vol.89, pp.171-178, 2016. ,
Railway Track Circuit Fault Diagnosis Using Recurrent Neural Networks, IEEE Transactions on Neural Networks & Learning Systems, pp.1-11, 2016. ,
Hierarchical adaptive deep convolution neural network and its application to bearing fault diagnosis, Measurement, vol.93, pp.490-502, 2016. ,
DOI : 10.1016/j.measurement.2016.07.054
Fault Diagnosis in Industrial Chemical Processes Using Interpretable Patterns Based on Logical Analysis of Data, Expert Systems with Applications, 2017. ,
MILP approach to pattern generation in logical analysis of data ,
, Discrete Applied Mathematics, vol.157, issue.4, pp.749-761, 2009.
Fault diagnosis in power transformers using multi-class logical analysis of data, Journal of Intelligent Manufacturing, vol.25, issue.6, pp.1429-1439, 2014. ,
