Weak and strong mean-field limits for stochastic Cucker-Smale particle systems
We consider a particle system with a mean-field-type interaction perturbed by some common and individual noises. When the interacting kernels are sublinear and only locally Lipschitz-continuous, relying on arguments based on the tightness of random measures in Wasserstein spaces, we are able to construct a weak solution of the corresponding limiting SPDE. In a setup where the diffusion coefficient on the environmental noise is bounded, this weak convergence can be turned into a strong L^p(Ω) convergence and the propagation of chaos for the particle system can be established. The systems considered include perturba- tions of the Cucker-Smale model for collective motion.
