Magic-state distillation with low overhead, Physical Review A, vol.86, issue.5, p.52329, 2012. ,
Distillation with sublogarithmic overhead, Physical Review Letters, vol.120, issue.5, p.50504, 2018. ,
Comparing the overhead of topological and concatenated quantum error correction, 2013. ,
Multilevel distillation of magic states for quantum computing, Physical Review A, vol.87, issue.4, p.42305, 2013. ,
Quantum computation with realistic magic-state factories, Physical Review A, vol.95, issue.3, p.32338, 2017. ,
Qutrit magic state distillation, New Journal of Physics, vol.14, issue.6, p.63006, 2012. ,
Magic-state distillation in all prime dimensions using quantum reed-muller codes, Physical Review X, vol.2, issue.4, p.41021, 2012. ,
Qudit versions of the qubit ?/8 gate, Physical Review A, vol.86, issue.2, p.22316, 2012. ,
Enhanced fault-tolerant quantum computing in d-level systems, Physical Review Letters, vol.113, issue.23, p.230501, 2014. ,
Diagonal gates in the clifford hierarchy, Physical Review A, vol.95, issue.1, p.12329, 2017. ,
Demonstrating the viability of universal quantum computation using teleportation and single-qubit operations, Nature, vol.402, issue.6760, p.390, 1999. ,
Stabilizer codes and quantum error correction. arXiv preprint quant-ph/9705052, 1997. ,
Codes and protocols for distilling t, controlled-s, and toffoli gates, p.71, 2018. ,
On products and powers of linear codes under componentwise multiplication. Algorithmic arithmetic, geometry, and coding theory, Contemp. Math, vol.637, pp.3-78, 2015. ,
The theory of error-correcting codes, 1977. ,
, Since the all 1s vector is in C ?
