Non-Asymptotic Sequential Tests for Overlapping Hypotheses and application to near optimal arm identification in bandit models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Sequential Analysis Année : 2021
In this paper, we study sequential testing problems with overlapping hypotheses. We first focus on the simple problem of assessing if the mean µ of a Gaussian distribution is $≥ ε− or ≤ε; if µ ∈ (−ε,ε)$, both answers are considered to be correct. Then, we consider PAC-best arm identification in a bandit model: given K probability distributions on R with means $µ_1,. .. , µ_K$ , we derive the asymptotic complexity of identifying, with risk at most $δ$, an index $I ∈ {1,. .. , K}$ such that $µ_I ≥ max_i µ_i −ε$. We provide non asymptotic bounds on the error of a parallel General Likelihood Ratio Test, which can also be used for more general testing problems. We further propose lower bound on the number of observation needed to identify a correct hypothesis. Those lower bounds rely on information-theoretic arguments, and specifically on two versions of a change of measure lemma (a high-level form, and a low-level form) whose relative merits are discussed.
GK_SQA.pdf (331.76 Ko) Télécharger le fichier
hal-02123833 , version 1 (09-05-2019)
hal-02123833 , version 2 (17-11-2021)
Aurélien Garivier, Emilie Kaufmann. Non-Asymptotic Sequential Tests for Overlapping Hypotheses and application to near optimal arm identification in bandit models. Sequential Analysis, 2021. ⟨hal-02123833v2⟩
154 Consultations
169 Téléchargements
