Abstract : Non-invasive edge detection of leaves is the key step of leaf feature extraction. Traditional algorithms for edge detection of leaves are usually invasive, since the detection is carried out after the leaves are picked. We apply order morphology in this study to non-invasive edge detection of leaves. First we analyze the algorithm for order morphology edge detection of leaves. In particular, the impact of structural elements and percentile on the detection is discussed. Based on the theory of order morphology transform of leaf images, the operator for detecting the leaf edge is constructed. Finally simulation experiment is carried out on leaf images under the conditions of natural illumination and artificial noise, respectively. Results show that the proposed algorithm is accurate and fast in leaf edge extraction and not sensitive to noise.
https://hal.inria.fr/hal-02124217
Contributor : Hal Ifip <>
Submitted on : Thursday, May 9, 2019 - 1:36:34 PM Last modification on : Thursday, May 9, 2019 - 1:42:12 PM
File
Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed
until : 2022-01-01
Yanlei Xu, Qi Zhang, Chenxiao Li, Xindong Wang, Xiaotian Meng. Non-invasive Edge Detection of Leaves Based on Order Morphology. 11th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Aug 2017, Jilin, China. pp.428-439, ⟨10.1007/978-3-030-06137-1_39⟩. ⟨hal-02124217⟩
