3D Reconstruction of Agriculture and Forestry Crops (in Chinese), Transactions of the Chinese Society for Agricultural Machinery, vol.45, issue.6, pp.38-46, 2014. ,
3-Dimentional Morphology Simulation of Tomato Canopy-Based on Measured Data (in Chinese), Journal of Chinese Agricultural Mechanization Research, vol.34, issue.2, pp.172-176, 2012. ,
Azimuthal Distribution of Maize Plant Leaves Determined by 3D Digitizer (in Chinese), Acta Agronomica Sinica, vol.32, issue.6, pp.791-798, 2006. ,
Research on Plant 3-D Information Acquisition Method (in Chinese), Transactions of the Chinese Society of Agricultural Engineering, vol.28, issue.3, pp.142-147, 2012. ,
High-precision Laser Scanning System for Capturing 3D Plant Architecture and Analysing Growth Ofcereal Plants, Biosystems Engineering, vol.121, issue.18, pp.1-11, 2014. ,
Robotized Plant Probing: Leaf Segmentation Utilizing Time-of-fight Data, IEEE Robot. Automat. Mag, vol.20, issue.3, pp.50-59, 2013. ,
Denoising Method of 3-D Point Cloud Data of Plants Obtained by Kinect (in Chinese), Transactions of the Chinese Society for Agricultural Machinery, vol.47, issue.1, pp.331-336, 2016. ,
Three-dimensional Reconstruction of Plant Architecture Based on Multiple View Stereo Method and Accuracy Evaluation (in Chinese), Transactions of the Chinese Society of Agricultural Engineering, vol.31, issue.11, pp.209-214, 2015. ,
3D Morphological Reconstruction of Cucumber Leaf Based on Multiple Images (in Chinese), Transactions of the Chinese Society of Agricultural Engineering, vol.25, issue.2, pp.141-144, 2009. ,
Evaluation of a Strawberry-harvesting Robot in a Field Test, Biosystems Engineering, vol.105, issue.2, pp.160-171, 2010. ,
Bilateral Mesh Denoising, ACM Trans. Graph, vol.22, issue.3, pp.950-953, 2003. ,
Bilateral Normal Filtering for Mesh Denoising, IEEE Trans. Vis. Comput. Graph, vol.17, issue.10, pp.1521-1530, 2011. ,
Mesh Denoising by Improved 3D Geometric Bilateral Filter, Fourth National Conference on Computer Vision, Pattern Recognition, Image Processing and Graphics, pp.1-4, 2013. ,
Anisotropic Smoothing of Point Sets, Computer Aided Geometric Design, vol.22, issue.7, pp.680-692, 2005. ,
Efficient Surface Reconstruction From Noisy Data Using Regularized Membrane Potentials, IEEE Trans. Image Processing, vol.18, issue.5, pp.1119-1134, 2009. ,
Robust Denoising of Unorganized Point Clouds, IEEE Conference Anthology, pp.1-3, 2013. ,
Feature-Preserving Mesh Denoising Via Normal Guided Quadric Error Metrics, Optics and Lasers in Engineering, vol.62, issue.6, pp.57-68, 2014. ,
Density-based Denoising of Point Cloud, 2016. ,
A Density-Based Algorithm for Discovering Clusters in Large Spatial Databases with Noise, Proceedings of the Second International Conference on Knowledge Discovery and Data Mining (KDD-96), pp.226-231, 1996. ,
A Fast Approximation of the Bilateral Filter Using a Signal Processing Approach, International Journal of Computer Vision, vol.81, issue.1, pp.24-52, 2009. ,
A Survey on Structure from Motion, 2017. ,
Distinctive Image Features from Scale-Invariant Keypoints, International Journal of Computer Vision, vol.60, issue.2, pp.91-110, 2004. ,
Accurate Multi-View Reconstruction Using Robust Binocular Stereo and Surface Meshing, 2008 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, pp.1-8, 2008. ,
A Systemic Point-Cloud De-noising and Smoothing Method for 3D Shape Reuse, 12th International Conference on Control Automation Robotics & Vision, ICARCV 2012, pp.1722-1727, 2012. ,
Noise Classification Denoising Algorithm for Point Cloud Model (in Chinese), Computer Engineering and Applications, vol.52, issue.20, pp.188-192, 2016. ,
