Long-Term Distribution Patterns of Chlorophyll-a Concentration in China's Largest Freshwater Lake: MERIS Full-Resolution Observations with a Practical Approach, Remote Sensing, vol.7, pp.275-299, 2014. ,
Application of a partial least-squares regression model to retrieve chlorophyll-a concentrations in coastal waters using hyper-spectral data, Ocean Science Journal, vol.51, issue.2, pp.209-221, 2016. ,
Estimation of chlorophyll-a concentration of different seasons in outdoor ponds using hyperspectral imaging, Talanta, vol.147, pp.422-429, 2016. ,
Relationship between spectral reflectance and chlorophyll-a concentration in the eutrophic Lake Togo-ike, Proceedings of SPIE -The International Society, vol.9240, pp.92400-92400, 2014. ,
Monitoring and modelling of chlorophyll-a concentrations in rivers using a high-resolution satellite image: a case study in the Nakdong river, International Journal of Remote Sensing, vol.36, issue.6, pp.1645-1660, 2015. ,
In situ estimation of water quality parameters in freshwater aquaculture ponds using hyper-spectral imaging system, ISPRS Journal of Photogrammetry and Remote Sensing, vol.66, issue.4, pp.463-472, 2011. ,
Determination of Chlorophyll Content and Tropic St ate of Lakes Using Field Spectrometer and IRS-1 C Satellite Data in the Mecklenburg Lake District ,
, Remote Sensing of Environment, vol.73, pp.227-235, 2000.
A Semi-operative Approach to Lake Water Quality Retrieval from Remote Sensing Data, The Science of the Tot al Environment, vol.268, pp.79-93, 2001. ,
Water quality remote sensing in the visible spectrum, International Journal of Remote Sensing, vol.19, issue.5, pp.957-979, 1998. ,
Research advances in water quality monitoring technology based on UV-Vis spectrum analysis ,
, Spectroscopy & Spectral Analysis, vol.31, issue.4, p.1074, 2011.
Application of a water quality monitoring instrument based on UV-vis spectroscopy ,
, Water Resources Protection, 2008.
In-situ Monitoring of Water Quality on the Basis of Spectral Reflectance. Ship-borne Experiments for the Development of Remote Sensing Algorithms Especially for the Estimation of Algae Content in Natural Waters ,
, Internationale Revue Der Gesamten Hydrobiologie Und Hydrographie, vol.73, pp.61-72, 1988.
The peak near 700 nm on radiance spectra of algae and water: relationships of its magnitude and position with chlorophyll concentration ,
, International Journal of Remote Sensing, vol.13, issue.17, pp.3367-3373, 2007.
Study on the spectral reflectivity models of different water quality parameters in Huangpu river, J]. Journal of Infrared & Millimeter Waves, vol.25, issue.4, pp.282-286, 2006. ,
Spectral reflectance is a reliable water-quality estimator for small, highly turbid wetlands, Wetlands Ecology & Management, vol.23, issue.5, pp.933-946, 2015. ,
