Performance of two low-cost GPS receivers for ground speed measurement under varying speed conditions. Precision Agric, vol.18, pp.264-277, 2017. ,
A comparison of several approaches for velocity determination with GPS. Acta Geodaetica et Cartographica Sinica, vol.31, pp.217-221, 2002. ,
Research of high-accurate rotating speed method. Instrument Technique and Sensor, vol.10, pp.88-90, 2013. ,
A method for speed and ranging of trains based on Doppler sensor. Microcomputer & Its Applications, vol.31, pp.80-82, 2012. ,
The measurement method of vehicle speed in vehicle testing, Straits Science, issue.12, pp.13-15, 2010. ,
Rotational speed sensors limitations, pre-processing and automotive applications, IEEE Transactions on Instrumentation and Measurement, vol.13, issue.2, pp.16-23, 2010. ,
Measurements of vehicle velocity in tractor accelerating slip-ratio real-time measuring, Journal of Agricultural Mechanization Research, vol.31, issue.4, pp.237-240, 2009. ,
, 7: International organization for standardization, Implement messages application layer, ISO 11783, 2015.
Evaluation of ground speed measurements for agricultural machinery, Transactions of the CSAE, vol.26, issue.6, pp.141-145, 2010. ,
Comparative analysis on velocity determination by GPS single point, Journal of Navigation and Positioning, vol.5, issue.1, p.99, 2017. ,
Single Station Velocity Estimation: GPS vs BDS, Journal of Navigation and Positioning, vol.3, issue.3, pp.39-42, 2015. ,
