Visible, near infrared, mid infrared or combined diffuse reflectance spectroscopy for simultaneous assessment of various soil properties, Geoderma, vol.131, issue.1, pp.59-75, 2006. ,
Evaluation of soil structural quality using vis-nir spectra, Soil and Tillage Research, vol.146, pp.108-117, 2015. ,
, , 2016.
Non-destructive discrimination of paddy seeds of different storage age based on vis/nir spectroscopy, Journal of Stored Products Research, vol.44, issue.3, pp.264-268, 2008. ,
The spectrum-based learner: A new local approach for modeling soil vis-nir spectra of complex datasets, Geoderma, vol.195, pp.268-279, 2013. ,
Distance and similarity-search metrics for use with soil vis-nir spectra, Geoderma, vol.199, pp.43-53, 2013. ,
Estimating soil organic carbon from soil reflectance: a review, Precision Agriculture, vol.11, issue.1, pp.82-99, 2010. ,
Support vector machine regression (svr/ls-svm)an alternative to neural networks (ann) for analytical chemistry? comparison of non-linear methods on near infrared (nir) spectroscopy data, Analyst, vol.136, issue.8, pp.1703-1712, 2011. ,
Machine learning based prediction of soil total nitrogen, organic carbon and moisture content by using vis-nir spectroscopy, Biosystems Engineering, vol.152, pp.104-116, 2016. ,
Variable selection in regressiona tutorial, Journal of Chemometrics, vol.24, pp.728-737, 2010. ,
Elimination of uninformative variables for multivariate calibration, Analytical chemistry, vol.68, issue.21, pp.3851-3858, 1996. ,
Key wavelengths screening using competitive adaptive reweighted sampling method for multivariate calibration, Analytica chimica acta, vol.648, issue.1, pp.77-84, 2009. ,
Iteratively variable subset optimization for multivariate calibration, RSC Advances, vol.5, issue.116, pp.95771-95780, 2015. ,
Soil moisture and organic matter prediction of surface and subsurface soils using an nir soil sensor, Computers and electronics in agriculture, vol.32, issue.2, pp.149-165, 2001. ,
Soil component in the 2009 lucas survey. Land quality and land use information in the European Union, pp.209-220, 2011. ,
European soil data centre: Response to european policy support and public data requirements, Land Use Policy, vol.29, issue.2, pp.329-338, 2012. ,
LUCAS Topsoil Survey: methodology, data and results, Publications Office, 2013. ,
Review of the most common preprocessing techniques for near-infrared spectra, TrAC Trends in Analytical Chemistry, vol.28, issue.10, pp.1201-1222, 2009. ,
Pls-regression: a basic tool of chemometrics. Chemometrics and intelligent laboratory systems, vol.58, pp.109-130, 2001. ,
Determination of soil properties with visible to near-and mid-infrared spectroscopy: Effects of spectral variable selection, Geoderma, vol.223, pp.88-96, 2014. ,
Comparing different multivariate calibration methods for the determination of soil organic carbon pools with visible to near infrared spectroscopy, Geoderma, vol.166, issue.1, pp.198-205, 2011. ,
Soil ph value, organic matter and macronutrients contents prediction using optical diffuse reflectance spectroscopy, Computers and Electronics in Agriculture, vol.111, pp.69-77, 2015. ,
, R: A Language and Environment for Statistical Computing. R Foundation for Statistical Computing, 2016.
An introduction to the prospectr package, 2013. ,
Smoothing and differentiation of data by simplified least squares procedures, Analytical chemistry, vol.36, issue.8, pp.1627-1639, 1964. ,
