Estimation of Regional Surface Resistance to Evapotranspiration from NDVI and Thermal-IR AVHRR Data, J. Appl. Meteoro, vol.28, pp.276-284, 1989. ,
Using Spatial Context in Satellite Data to Infer Regional Scale Evapotranspiration, IEEE T. Geosci. Remote, vol.28, pp.940-948, 1990. ,
A New Look at The Simplified Method for Remote Sensing of Daily Evapotranspiration, Remote Sens. Environ, vol.54, pp.161-167, 1995. ,
Mapping Surface energy Balance Components by Combining Landsat Thematic Mapper and Ground-based Meteorological Data, Remote Sens. Environ, vol.30, pp.77-87, 1989. ,
A Simple Interpretation of The Surface temperature/vegetation Index Space for Assessment of Surface Moisture Status, Remote Sens. Environ, vol.79, pp.213-224, 2002. ,
Evaluating Land Surface Moisture Conditions from The Remotely Sensed Temperature/vegetation Index Measurements: An Exploration with The Simplified Simple Biosphere Model, Remote Sens. Environ, vol.79, pp.225-242, 2002. ,
Evaluating Soil Moisture Status in China Using the Temperature/Vegetation Dryness Index (TVDI), J. Remote Sens, vol.5, pp.420-427, 2003. ,
Evaluating Soil Moisture Status in XinJiang Using theTemperature Vegetation Dryness Index . Remote Sens, Technology Appl, vol.6, pp.473-478, 2004. ,
Remote Sensing and Impact Estimation for Sichuan Hot-drought Based on Temperature Vegetation Dryness Index, Trans. Chinese Soc. Agricultural Engineering, vol.9, pp.141-146, 2007. ,
Integrating Temperature Vegetation Dryness Index (TVDI) and Regional Water Stress Index (RWSI) for Drought Assessment with the Aid of LANDSAT TM/ETM+ Images, Int. J. Appl. EARTH Obs, vol.13, pp.495-503, 2011. ,
Drought Monitoring Based on Landsat 8 Data and Temperature-vegetation Index ,
, J.Natural Disasters, vol.2, pp.43-52, 2016.
Mono-window Algorithm for Retrieving Land Surface Temperature from Landsat TM6 Data, Acta Geographica Sinica, issue.04, pp.456-466, 2001. ,
On the Relationship between Thermal Emissivity and The Normalized Difference Vegetation Index for Natural Surfaces, Int. J. Remote Sens, vol.14, pp.1119-1131, 1993. ,
Emissivity of Pure and Sea Waters for the Model Sea Surface in the Infrared Window Regions, Remote Sens. Environ, vol.24, pp.313-329, 1988. ,
