Ginger-an herbal medicinal product with broad anti-inflammatory actions, J. Med. Food, vol.8, issue.2, pp.125-132, 2005. ,
Ginger-Mechanism of action in chemotherapy-induced nausea and vomiting: A review, Crit. Rev. Food Sci, vol.57, issue.1, pp.141-146, 2017. ,
Carotenoids in photosynthesis, Photochem. Photobio, vol.63, issue.3, pp.257-264, 1996. ,
Function of the photosynthetic apparatus of oilseed winter rape under elicitation by Phoma lingam phytotoxins in relation to carotenoid and phenolic levels, Acta. Physiol. Plant, vol.36, issue.2, pp.295-305, 2014. ,
Batch and fed-batch culture of Scenedesmus incrassatulus: Effect over biomass, carotenoid profile and concentration, photosynthetic efficiency and non-photochemical quenching, Algal. Res, vol.13, pp.41-52, 2016. ,
Enhancement of carotenoid and bacterio chlorophyll by high salinity stress in photosynthetic bacteria, Int. Biodeter. Biodegr, vol.121, pp.91-96, 2017. ,
Response of chlorophyll, carotenoid and SPAD-502 measurement to salinity and nutrient stress in wheat (Triticum aestivum L.), Agron. J, vol.7, issue.3, p.61, 2017. ,
Nitrogen concentration affects nutrient and carotenoid accumulation in parsley, J. Plant Nutr, vol.28, pp.285-297, 2005. ,
The role of xanthophyll cycle carotenoids in the protection of photosynthesis, Trends Plant. Sci, vol.1, issue.1, pp.21-26, 1996. ,
Estimation of carotenoid content at the canopy scale using the carotenoid triangle ratio index from in situ and simulated hyperspectral data, J. Appl. Remote Sens, vol.10, issue.2, p.26035, 2016. ,
Estimation of canopy carotenoid content of winter wheat using multi-angle hyperspectral data, Adv. Space Res, vol.60, issue.9, 1988. ,
Estimating leaf carotenoid contents of shadegrown tea using hyperspectral indices and PROSPECT-D inversion, Int. J. Remote Sens, vol.39, issue.5, pp.1306-1320, 2018. ,
Disentangling the relationships between plant pigments and the photochemical reflectance index reveals a new approach for remote estimation of carotenoid content, Remote Sens. Environ, vol.115, pp.628-635, 2011. ,
Chlorophylls and carotenoids: pigments of photosynthetic biomembranes, Method Enzymol, vol.148, issue.34, pp.350-382, 1987. ,
Quantifying chlorophylls and caroteniods at leaf and canopy scales: an evaluation of some hyperspectral approaches, Remote Sens. Environ, vol.31, issue.2, pp.221-230, 1998. ,
Assessing carotenoid content in plant leaves with reflectance spectroscopy, Photochem. Photobiol, vol.75, issue.3, pp.272-281, 2002. ,
Assessing vineyard condition with hyperspectral indices: leaf and canopy reflectance simulation in a row-structured discontinuous canopy, Remote Sens. Environ, vol.99, issue.3, pp.271-287, 2005. ,
Two-dimensional empirical wavelet transform based supervised hyperspectral image classification, Isprs. J. Photogramm, vol.133, pp.37-45, 2017. ,
Wide-stripe noise removal method of hyperspectral image based on fusion of wavelet transform and local interpolation, Opt. Rev, vol.24, pp.177-187, 2017. ,
Land surface temperature and emissivity retrieval from field-measured hyperspectral thermal infrared data using wavelet transform, Remote Sens, vol.9, issue.5, p.454, 2017. ,
