, China Water Resources Bulletin, 2016.
, National Bureau of Statistics of the People's Republic of China
Application of soil water balance model in soil moisture prediction ,
, Water Resources & Hydropower of Northeast China, vol.23, issue.246, pp.49-51, 2005.
Research on the Forecast Method of Soil Water Dynamic Process in Corn-land ,
, Acta Ecologica Sinica, vol.17, issue.3, pp.245-251, 1997.
Study on Soil Moisture Forecast Method Based on Exponential Depletion Relations for Cotton Drip Irrigation under Mulch in Xinjiang Autonomous Region ,
, Water-saving Irrigation, vol.8, pp.5-7, 2008.
Application of time series autoregressive model in soil moisture prediction, vol.2, pp.42-46, 2014. ,
Matlab neural network application design, 2012. ,
A simple soil water simulation model for assessing the irrigation requirements of wheat ,
, Israel J Agric Res, vol.22, issue.4, pp.201-213, 1972.
Mapping root zone soil moisture using remotely sensed optical imagery, J].Journal of Irrigatio nand Drainage Engineering, vol.129, issue.5, pp.326-335, 2003. ,
Francesco Posa,etc. Soil Moisture Retrieval From Remotely Sensed Data: Neural Network Approach Versus Bayesian Method ,
, IEEE Transactions on Geoscience & Remote Sensing, vol.46, issue.2, pp.547-557, 2008.
Artificial Neural Network for the Estimation of Soil Moisture and Surface Roughness1 ,
, Russian Agricultural Sciences, vol.36, pp.428-432, 2010.
Kok Yeow You,Mohamad Ngasri Dimon.A modified microstrip ring resonator sensor with lumped element modeling for soil moisture and dielectric preditions measurement ,
, , vol.94, pp.119-125, 2016.
Predicting the mobile water content of vineyard soils in New South Wales ,
, Agricultural Water Management, vol.148, pp.34-42, 2015.
Study of artificial neural network prediction model of soil moisture in farmland ,
, , vol.35, pp.25-32, 1998.
Application of Support Vector Regression Machines in Soil Moisture Prediction Based on Bacteria Foraging Optimization Algorithm, Bulletin of Soil and Water Conservation, vol.36, pp.131-135, 2016. ,
Study of ARIMA model on soil moisture content prediction ,
, Agricultural Research in the Arid Areas, vol.24, issue.2, pp.114-118, 2006.
Prediction for soil moisture in tobacco fields based on PCA and RBF neural network, J]. Transactions of the CSAE, vol.26, issue.8, pp.85-90, 2010. ,
Prediction of soil moisture based on multilayer neural network with multi-valued neurons, Transactions of the Chinese Society of Agricultural 19.Ji Ronghua ,
Short-term Prediction of Soil Moisture in Field Based on GM(1,1)Model Group, Transactions of The Chinese Society of Agricultural Machinery, vol.47, pp.401-407, 2016. ,
Stochastic Soil Moisture Estimation and Forecasting for Irrigated Fields ,
, Water Resoures Research, vol.22, pp.180-190, 1986.
Soil moisture estimation with ERS-1 SAR data in the East-German loess soil area, International Journal of Remote Sensing, vol.19, issue.2, pp.237-243, 1998. ,
Simulation of soil moisture content of a prairie field with SWAP93 ,
, Agricultural Water Management, vol.43, pp.139-149, 2000.
Estimation of a real soil moisture by use of terrain data ,
, , vol.82, pp.89-105, 2000.
Soil Moisture Modeling Based on Multiyear Observations in the Sahel, J].Journal Of Applied Meteorology, vol.41, pp.1140-1146, 2002. ,
Soil moisture estimation using an artificial neural network: a feasibility study ,
, Canadian Journal of Remote Sensing, vol.30, issue.5, pp.827-839, 2004.
On the relevance of using artificial neural networks for estimating soil moisture content ,
, Journal of arid Land, vol.362, pp.1-18, 2008.
A linear mixed effect (LME) model for soil water content estimation based on geophysical sensing: a comparison of an LME model and kriging with external drift ,
, Environmental Earth Sciences, vol.73, pp.1951-1960, 2015.
Spatial prediction of temporal soil moisture dynamics using HYDRUS-1D ,
, Hydrological Processes, vol.28, pp.171-185, 2014.
Study of Soil Water Forecast with Neural Network, Journal of Soil and Water Conservation, vol.17, issue.5, pp.59-62, 2003. ,
Spatial analysis methods and application of regional soil moisture ,
, ChineseAgricultural Science Bulletin, vol.28, issue.21, pp.311-316, 2012.
Research and development of soil moisture monitoring and forecasting system in farmland, Transactions of the Chinese Society of Agricultural Engineering, vol.32, issue.18, pp.140-146, 2016. ,
Using Gene-Expression Programming method and geographical location information to simulate evapotranspiration in Hunan and Hubei Provinces ,
, Chinese Journal of Eco-Agriculture, vol.23, issue.4, pp.490-496, 2015.
