Effects of cornstalk on organic matter content and microbial community structure in soil, Guizhou Agricultural Sciences, vol.44, issue.10, pp.77-83, 2016. ,
Effect of crop residue management in a rice-wheat cropping systems on growth and yield of crops and on soil fertility, Experimental Agriculture, vol.35, issue.4, pp.427-435, 1999. ,
Growth, yield and water productivity of zero till wheat as affected by rice straw mulch and irrigation schedule, Field Crops Research, vol.121, pp.209-225, 2011. ,
Design and experiment of chopping device with dynamic fixed knife coaxial for rice straw, Transactions of the CSAE, vol.31, issue.10, pp.11-19, 2015. ,
Performance evaluation of tractor mounted straw chopper cum spreader for paddy straw management, Indian Journal of Agricultural Research, vol.45, issue.1, pp.21-29, 2011. ,
Experiment and Optimization on Factors Affecting the Performance of Wheat Stalk Macerator Smashing Devices. Transactions of the Chinese Society for Agricultural Machinery, vol.38, 2007. ,
Design and experimental research of the field straw chopper with throwing cotton-stalk, Transactions of the CSAE, vol.22, issue.3, pp.68-72, 2006. ,
Simulation of agricultural cutting and transport processes, Landtechnik, vol.65, pp.372-375, 2010. ,
Simulation of the flow characteristics of a drip irrigation emitter with large eddy methods, Mathematical and Computer Modelling, vol.58, pp.497-506, 2013. ,
Development and validation of a 3D CFD model of drift and its application to air-assisted orchard sprayers, Biosystems engineering, vol.154, pp.62-75, 2017. ,
Optimization and test for spraying parameters of cotton defoliant sprayer, International journal of agricultural and biological engineering, vol.9, issue.4, pp.63-72, 2016. ,
Determination and generalization of the effects of design parameters on Francis turbine runner performance, Engineering Applications of Computational Fluid Mechanics, vol.10, issue.1, pp.547-566, 2016. ,
Numerical Simulation of Regulating Performance of Direct-Operated Pressure Regulator for a Microirrigation Lateral, IFIP AICT, vol.452, pp.285-303, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01420244
Numerical Simulation of Fluid Field for High-speed Cutting Grinding. Transactions of the Chinese Society for Agricultural Machinery, vol.41, pp.60-65, 2010. ,
, Research on Simulating the Wind Field of the Field Straw Chopper with Throwing Cotton Stalk. Transactions of the Chinese Society for Agricultural Machinery, vol.38, pp.67-69, 2007.
Investigation of Flow Behavior around Corotating Blades in a Double-Spindle Lawn Mower Deck, International Journal of Rotating Machinery, vol.1, pp.77-89, 2005. ,
Combined stalk-stubble breaking and mulching machine, Soil Tillage Research, vol.107, pp.42-48, 2010. ,
Working Mechanism and Parameters Determination of Field Straw Chopper, Transactions of the CSAE, vol.11, issue.4, pp.62-66, 1995. ,
, 3-D Modeling of Axial Fans. Applied Mathematics, pp.4632-651, 2013.
Velocity Measurements Near an Automotive Cooling Fan, 2001. ,
Numerical predictions of indoor climate in large industrial premises. A comparison between different k-? models supported by field measurements, Building and Environment, vol.42, pp.3872-3882, 2007. ,
Computations with the multiple reference frame technique: Flow and temperature fields downstream of an axial fan, Numerical Heat Transfer, vol.71, issue.5, pp.488-510, 2017. ,
Design and Experiment of Straw-chopping Device with Chopping and Fixed Knife Supported Slide Cutting. Transactions of the Chinese Society for Agricultural Machinery, vol.47, pp.108-116, 2016. ,
Performance Experiments of Field Straw Chopper for Mulching or Reclaiming, Journal of Agricultural Mechanization Research, vol.4, pp.126-128, 2009. ,
, Study on Working Parameters of Knife Roller of Field Straw Chopper for Mulching or Reclaiming. Transactions of the Chinese Society for Agricultural Machinery, vol.38, pp.82-85, 2007.
Global overview of research and development of crop residue management machinery, Applied Engineering in Agriculture, vol.33, issue.3, pp.329-344, 2017. ,
Parameter determination and examination of the 4Q-1.5-type straw stalk grinder main working part, Journal of Agricultural Mechanization Research, vol.9, pp.74-76, 2006. ,
Simulation of flow field and performance of cross-flow fan, Chinese journal of mechanical engineering, vol.40, issue.4, pp.62-66, 2004. ,
