New interface
Journal articles
Nonlinear mapping and distance geometry
Alain Franc 1, 2 Pierre Blanchard 3 Olivier Coulaud 3
1 PLEIADE - from patterns to models in computational biodiversity and biotechnology
LaBRI - Laboratoire Bordelais de Recherche en Informatique, Inria Bordeaux - Sud-Ouest, BioGeCo - Biodiversité, Gènes & Communautés
3 HiePACS - High-End Parallel Algorithms for Challenging Numerical Simulations
Abstract : Distance Geometry Problem (DGP) and Nonlinear Mapping (NLM) are two well established questions: DGP is about finding a Euclidean realization of an incomplete set of distances in a Euclidean space, whereas Nonlinear Mapping is a weighted Least Square Scaling (LSS) method. We show how all these methods (LSS, NLM, DGP) can be assembled in a common framework, being each identified as an instance of an optimization problem with a choice of a weight matrix. We study the continuity between the solutions (which are point clouds) when the weight matrix varies, and the compactness of the set of solutions (after centering). We finally study a numerical example, showing that solving the optimization problem is far from being simple and that the numerical solution for a given procedure may be trapped in a local minimum.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-02124882
Contributor : Olivier Coulaud Connect in order to contact the contributor
Submitted on : Friday, May 10, 2019 - 8:55:51 AM
Last modification on : Friday, July 8, 2022 - 10:08:07 AM
Links full text
Identifiers
Collections
Citation
Alain Franc, Pierre Blanchard, Olivier Coulaud. Nonlinear mapping and distance geometry. Optimization Letters, 2020, 14 (2), pp.453-467. ⟨10.1007/s11590-019-01431-y⟩. ⟨hal-02124882⟩
Share
Metrics
Record views
83
