Multi-view Relighting using a Geometry-Aware Network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2019
We propose the first learning-based algorithm that can relight images in a plausible and controllable manner given multiple views of an outdoor scene. In particular, we introduce a geometry-aware neural network that utilizes multiple geometry cues (normal maps, specular direction, etc.) and source and target shadow masks computed from a noisy proxy geometry obtained by multi-view stereo. Our model is a three-stage pipeline: two subnetworks refine the source and target shadow masks, and a third performs the final relighting. Furthermore, we introduce a novel representation for the shadow masks, which we call RGB shadow images. They reproject the colors from all views into the shadowed pixels and enable our network to cope with inacuraccies in the proxy and the non-locality of the shadow casting interactions. Acquiring large-scale multi-view relighting datasets for real scenes is challenging, so we train our network on photorealistic synthetic data. At train time, we also compute a noisy stereo-based geometric proxy, this time from the synthetic renderings. This allows us to bridge the gap between the real and synthetic domains. Our model generalizes well to real scenes. It can alter the illumination of drone footage, image-based renderings, textured mesh reconstructions, and even internet photo collections.
Multi-view-Relighting.pdf (44.56 Mo) Télécharger le fichier
hal-02125095 , version 1 (10-05-2019)
Julien Philip, Michaël Gharbi, Tinghui Zhou, Alexei A Efros, George Drettakis. Multi-view Relighting using a Geometry-Aware Network. ACM Transactions on Graphics, In press, 38, ⟨10.1145/3306346.3323013⟩. ⟨hal-02125095⟩
435 Consultations
229 Téléchargements
