Measuring the Amazon Web Services (AWS) WAN Infrastructure - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Modern applications necessitate geographically-distributed fragments over several data centers (DCs). Typical examples include stream or batch processing of geo-distributed data, or the redirection of clients to the optimal data replica. While little is known on inter-DC networks, the common belief is that they are not as well provisioned as intra-DC networks. They could thus be the bottleneck of multi-DC applications. As Amazon Web Services (AWS) is arguably the most popular Infrastructure-as-a-Service (IaaS) cloud provider, our focus is on the WAN connectivity offered by AWS in-between its DCs. We present preliminary results of a measurement campaign of the AWS WAN infrastructure, relying on traceroute measurements. Our initial observations highlight the complexity of the AWS infrastructure, which makes use of a variety of network solutions, including MPLS and Carrier-Grade NAT (CGNAT)
aws_cores.pdf (191.79 Ko) Télécharger le fichier
hal-02128052 , version 1 (13-05-2019)
  • HAL Id : hal-02128052 , version 1
Quentin Jacquemart, Alessandro Baldi Vitali, Guillaume Urvoy-Keller. Measuring the Amazon Web Services (AWS) WAN Infrastructure. CoRes 2019, 2019, Saint Laurent de la Cabrerisse, France. ⟨hal-02128052⟩
387 Consultations
246 Téléchargements
