An improved segmentation approach for planar surfaces from unstructured 3d point clouds, The Photogrammetric Record, vol.25, issue.129, pp.5-23, 2010. ,
A fast and accurate plane detection algorithm for large noisy point clouds using filtered normals and voxel growing, Proceedings of the 5th International Symposium on 3D Data Processing, Visualization and Transmission (3DPVT'10), 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-01259363
Random sample consensus: A paradigm for model fitting with, Communications of the ACM, vol.24, pp.381-395, 1981. ,
, Surface reconstruction from unorganized points, vol.26, 1992.
A novel algorithm for planar extracting of 3d point clouds, Proceedings of the International Conference on Internet Multimedia Computing and Service, pp.142-145, 2016. ,
Plane segmentation and decimation of point clouds for 3d environment reconstruction, Consumer Communications and Networking Conference (CCNC), pp.43-49, 2013. ,
Planar simplification and texturing of dense point cloud maps, Mobile Robots (ECMR), 2013. ,
Bayesian graph-cut optimization for wall surfaces reconstruction in indoor environments, The Visual Computer, vol.33, issue.10, pp.1347-1355, 2017. ,
3d point cloud segmentation: A survey, Robotics, Automation and Mechatronics (RAM), 2013 6th IEEE Conference on, pp.225-230, 2013. ,
Planar segmentation of indoor terrestrial laser scanning point clouds via distance function from a point to a plane, Optics and Lasers in Engineering, vol.64, pp.23-31, 2015. ,
Automatic planar shape segmentation from indoor point clouds, Proceedings of the 15th ACM SIGGRAPH Conference on Virtual-Reality Continuum and Its Applications in Industry, vol.1, pp.363-372, 2016. ,
DOI : 10.1145/3013971.3014008
Plane detection in point cloud data, Proceedings of the 2nd int conf on machine control guidance, vol.1, pp.95-104, 2010. ,
