Reorientation Method to Suppress Simulator Sickness in Home VR Contents Using HMD - Archive ouverte HAL Access content directly
Conference Papers Year : 2018
(1) , (1) , (2) , (1)
1
2
While home-use HMD including Oculus Rift has been widely spread in the market today, simulator sickness mainly caused by difference between visual information and body sensation has taken up as a problem. Even though it has been proved that simulator sickness is reduced by reflecting actual physical movement to a VR space, many of approaches ever proposed had various restrictions and mechanisms easy to cause simulator sickness. In the current study, such an approach for moving within a VR space is proposed for home-use HMD that is less likely to cause simulator sickness.
472623_1_En_22_Chapter.pdf (3.94 Mo) Télécharger le fichier
Dates and versions
hal-02128640 , version 1 (14-05-2019)
Attribution - CC BY 4.0
Identifiers
Cite
Yuki Ueda, Kazuma Nagata, Soh Masuko, Junichi Hoshino. Reorientation Method to Suppress Simulator Sickness in Home VR Contents Using HMD. 17th International Conference on Entertainment Computing (ICEC), Sep 2018, Poznan, Poland. pp.228-234, ⟨10.1007/978-3-319-99426-0_22⟩. ⟨hal-02128640⟩
74 View
36 Download
Share
