Adjusting Matching Algorithm to Adapt to Workload Fluctuations in Content-based Publish/Subscribe Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
When facing fluctuating workloads, can the performance of matching algorithms in a content-based publish/subscribe system be adjusted to adapt to the workloads? In this paper, we explore the idea of endowing matching algorithms with adaptability. The prerequisite for adaptability is to enable the matching algorithm to possess the ability to dynamically and quantitatively adjust its performance. We propose PSAM, a Predicate-Skipping Adjustment Mechanism that realizes dynamic performance adjustment by smoothly switching between exact matching and approximate matching, following the strategy of trading off matching precision in favor of matching speed. The PSAM mechanism is integrated into an existing matching algorithm, resulting in a performance-adjustable matching algorithm called Ada-Rein. To collaborate with Ada-Rein, we design PADA, a Performance Adjustment Decision Algorithm that is able to make proper performance adjustment plans in the presence of fluctuating workloads. The effectiveness of Ada-Rein and PADA is evaluated through a series of experiments based on both synthetic data and real-world stock traces. Experiment results show that adjusting the performance of Ada-Rein at the price of a small false positive rate, less than 0.1%, can shorten event latency by almost 2.1 times, which well demonstrates the feasibility of our exploratory idea.
1570479158.pdf (11.32 Mo) Télécharger le fichier
hal-02138748 , version 1 (24-05-2019)
Shiyou Qian, Weichao Mao, Jian Cao, Frédéric Le Mouël, Minglu Li. Adjusting Matching Algorithm to Adapt to Workload Fluctuations in Content-based Publish/Subscribe Systems. INFOCOM 2019 - IEEE International Conference on Computer Communications, Apr 2019, Paris, France. pp.1-9, ⟨10.1109/BDCloud.2018.00064⟩. ⟨hal-02138748⟩
141 Consultations
201 Téléchargements
