Inclination shallowing and preferred transitional VGP paths, Earth Planet. Sci. Lett, vol.140, pp.147-157, 1996. ,
DOI : 10.1016/0012-821x(96)00025-8
Apparent and true polar wander and the geometry of the geomagnetic field over the last 200 Myr, J. Geophys. Res, vol.107, issue.B11, p.2300, 2002. ,
Exploring the influence of the non-dipole field on magnetic records for field reversals and excursions, Geophys. J. Int, vol.168, pp.541-550, 2007. ,
The last two geomagnetic polarity reversals recorded in high deposition-rate sediments drifts, Nature, vol.389, pp.712-715, 1997. ,
Paleointensity of the Earth's magnetic field and K-Ar dating of the Louchadière volcanic flow (central France): New evidence for the Laschamp excursion, Geophys. Res. Lett, vol.16, issue.10, pp.1189-1192, 1989. ,
Records of geomagnetic reversals from volcanic islands of French Polynesia: 2. Paleomagnetic study of a flow sequence (1.2-0.6 Ma) from the island of Tahiti and discussion of reversal models, J. Geophys. Res, vol.95, issue.B3, pp.2727-2752, 1990. ,
Determination of rapid Deccan eruptions across the Cretaceous-Tertiary boundary using paleomagnetic secular variation: Results from a 1200-m-thick section in the Mahabaleshwar escarpment, J. Geophys. Res, vol.113, 2008. ,
Determination of rapid Deccan eruptions across the Cretaceous-Tertiary boundary using paleomagnetic secular variation: 2. Constraints from analysis of eight new sections and synthesis for a 3500-m-thick composite section, J. Geophys. Res, vol.114, p.6103, 2009. ,
Conditions for Earth-like geodynamo models, Earth Planet. Sci. Lett, vol.296, issue.3-4, pp.487-496, 2010. ,
DOI : 10.1016/j.epsl.2010.06.009
URL : https://hal.archives-ouvertes.fr/hal-00540375
Geographical distribution of transitional VGPs: Evidence for non-zonal equatorial symmetry during the Matuyama-Brunhes geomagnetic reversal, Earth Planet. Sci. Lett, vol.104, issue.1, p.90236, 1991. ,
Dependence of the duration of geomagnetic polarity reversals on site latitude, Nature, vol.428, pp.637-640, 2004. ,
Brunhes-Matuyama polarity transition in three deep-sea sediment cores, Philos. Trans. R. Soc. London, vol.306, pp.113-119, 1982. ,
DOI : 10.1098/rsta.1982.0071
URL : https://academiccommons.columbia.edu/doi/10.7916/D8V12FBR/download
An examination of simulated geomagnetic reversals from a palaeomagnetic perspective, Philos. Trans. R. Soc. London, vol.358, pp.1141-1170, 1768. ,
Matuyama-Brunhes reversal and Kamikatsura event at Maui: Paleomagnetic directions, 40 Ar/ 39 Ar ages and implications, Earth Planet. Sci. Lett, vol.222, pp.667-684, 2004. ,
PaleoMac: A MacintoshTM application for treating paleomagnetic data and making plate reconstructions, Geochem. Geophys. Geosyst, vol.4, issue.1, p.1007, 2003. ,
Paleomagnetic evidence for the transitional behaviour of the geomagnetic field, Geophys. J. R. Astron. Soc, vol.36, pp.577-598, 1974. ,
Paleomagnetic records of geomagnetic field reversals and the morphology of the transitional fields, Rev. Geophys, vol.17, pp.179-203, 1979. ,
On the possible occurrence of 'archaeomagnetic jerks' in the geomagnetic field over the past three millennia, Earth Planet. Sci. Lett, vol.214, issue.1-2, pp.362-367, 2003. ,
Palaeomagnetism of the Karoo igneous rocks in southern Africa, S. Afr. J. Geol, vol.100, issue.3, pp.195-212, 1997. ,
Paleosecular variation during sequential geomagnetic reversals from Hawaii, Earth Planet. Sci. Lett, vol.171, issue.1, pp.145-149, 1999. ,
DOI : 10.1016/s0012-821x(99)00145-4
) between the Gilbert-Gauss and the upper Mammoth reversals, Earth Planet. Sci. Lett, vol.234, pp.279-296, 2005. ,
Testing determinations of absolute paleointensity from the 1955 and 1960 Hawaiian flows, Earth Planet. Sci. Lett, vol.287, issue.3-4, pp.420-433, 2009. ,
Detailed paleomagnetic study of two volcanic polarity transitions recorded in eastern Iceland, Phys. Earth Planet. Inter, vol.115, issue.2, pp.119-135, 1999. ,
Directions and intensities of the Earth's magnetic field during a reversal: Results from the PermoTriassic Siberian trap basalts, Earth Planet. Sci. Lett, vol.218, issue.1-2, pp.197-213, 2004. ,
Brunhes-Matuyama polarity transition, Earth Planet. Sci. Lett, vol.29, p.90025, 1976. ,
Polarity transition records end the geomagnetic dynamo, Science, vol.196, pp.1329-1332, 1977. ,
Dipolar reversal states of the geomagnetic field and core-mantle dynamics, Nature, issue.6398, pp.789-794, 1992. ,
Magnetic source separation in Earth's outer core, Science, vol.321, issue.5897, p.1800, 2008. ,
An analysis of the geomagnetic field over the past 2000 years, Phys. Earth Planet. Inter, vol.106, issue.3-4, pp.115-120, 1998. ,
Quickly erupted volcanic sections of the Steens Basalt, Secular variation, tectonic rotation, and the Steens Mountain reversal, vol.9, p.11010, 2008. ,
The 40 Ar/ 39 Ar ages of the sill complex of the Karoo large igneous province: Implications for the Pliensbachian-Toarcian climate change, Geochem. Geophys. Geosyst, vol.9, p.6009, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00341781
The Central Atlantic Magmatic Province at the Triassic-Jurassic boundary: Paleomagnetic and 40 Ar/ 39 Ar evidence from Morocco for brief, episodic volcanism, Earth Planet. Sci. Lett, vol.228, issue.1-2, pp.143-160, 2004. ,
, Paleomagnetism of the Lesotho basalt, vol.139, pp.63-78, 1996.
Geomagnetic reversal paths, Nature, issue.6326, p.447, 1991. ,
Longitudinal confinement of geomagnetic reversal paths as a possible sedimentary artefact, Nature, vol.358, pp.226-230, 1992. ,
Paleomagnetic reconstruction of the global geomagnetic field evolution during the Matuyama/Brunhes transition: Iterative Bayesian inversion and independent verification, Earth Planet. Sci. Lett, vol.253, issue.1-2, pp.172-195, 2007. ,
Paleomagnetic volcanic data and geometric regularity of reversals and excursions, J. Geophys. Res, vol.103, pp.435-447, 1998. ,
The Steens mountain (Oregon) geomagnetic polarity transition: 1. Directional variation, duration of episodes, and rock magnetism, J. Geophys. Res, vol.90, pp.393-403, 1985. ,
The chemistry and petrogenesis of igneous rocks of the Karoo central area, southern Africa, in Petrogenesis of the Volcanic Rocks of the Karoo Province, Spec. Publ. Geol. Soc. S. Afr, vol.13, pp.27-68, 1984. ,
Geomagnetic secular variation over the past 5 m.y, Rev. Geophys, vol.13, pp.687-708, 1975. ,
The combined analysis of remagnetization circles and direct observations in palaeomagnetism, Earth Planet. Sci. Lett, vol.87, issue.1-2, pp.90072-90078, 1988. ,
Classification of the reversal test in paleomagnetism, Geophys. J. Int, vol.103, pp.725-729, 1990. ,
, Les traps du Karoo et les extinctions du Jurassique inférieur: Dynamique éruptive et perturbations de l'environnement, 2011.
An attempt to constrain the age, duration, and eruptive history of the Karoo flood basalt: Naude's Nek section (South Africa), J. Geophys. Res, vol.116, p.7403, 2011. ,
Complex polarity reversals in a geodynamo model, Earth Planet. Sci. Lett, vol.304, pp.168-179, 2011. ,
Geomagnetic secular variations and volcanic pulses in the Siberian traps, Geophys. Res. Abstr, vol.12, p.5872, 2010. ,
Absence of preferred longitude sectors for poles from volcanic records of geomagnetic reversals, Nature, vol.366, issue.6450, pp.53-57, 1993. ,
Absence of longitudinal confinement of poles in volcanic records of geomagnetic reversals, Nature, vol.316, pp.230-234, 1985. ,
, Revisiting the Jurassic geomagnetic reversal recorded in the Lesotho, 2003.
, , vol.155, pp.367-378
Paleomagnetic records of excursions and reversals: Possible biases caused by magnetization artefacts?, Phys. Earth Planet. Inter, vol.82, pp.27-48, 1994. ,
Geomagnetic changes across the last reversal recorded in lava flows from LaPalma, Canary islands, J. Geophys. Res, vol.101, pp.755-768, 1996. ,
Confounding influence of magnetic fabric on sedimentary records of a field reversal, Nature, vol.374, pp.246-249, 1995. ,
Paleoointensity of West Greenland Palaeocene basalts: Asymmetric intensity around the C27n-C26r transition, Phys. Earth Planet. Inter, vol.118, issue.1-2, pp.53-64, 2000. ,
New paleomagnetic pole and magnetostratigraphy of Faroe Islands flood volcanics, North Atlantic igneous province, Earth Planet. Sci. Lett, vol.201, issue.2, pp.261-276, 2002. ,
Paleomagnetism of large igneous provinces: Case-study from West Greenland, North Atlantic igneous province, Earth Planet. Sci. Lett, vol.214, issue.3-4, pp.367-371, 2003. ,
Rationale of geomagnetic reversal versus remanence recording process in rocks: A critical review, Earth Planet. Sci. Lett, vol.98, p.90086, 1990. ,
Some characteristics of geomagnetic reversals inferred from detailed volcanic records, C. R. Geosci, vol.335, issue.1, pp.5-6, 2003. ,
A few characteristic features of the geomagnetic field during reversals, The Earth's Magnetic Interior, pp.139-151, 2011. ,
Invariant and changing transitional field configurations in a sequence of geomagnetic reversals, Nature, issue.5986, pp.552-555, 1984. ,
Simulations of a timevarying non-dipole field during geomagnetic reversals and excursions, Phys. Earth Planet. Inter, vol.169, issue.1-4, pp.178-193, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00532170
Sequential geomagnetic reversals recorded in upper tortonian marine clays in western Crete (Greece), J. Geophys. Res, vol.93, issue.B2, pp.1131-1151, 1988. ,
Equatorial and mid-latitudes records of the last geomagnetic reversal from the Atlantic Ocean, Earth Planet. Sci. Lett, vol.94, pp.371-384, 1989. ,
, Palaeomagnetic constraints on the geometry of the geomagnetic field during reversals, vol.356, pp.400-407, 1992.
The palaeomagnetism of the Stormberg lavas of South Africa 1: Evidence for a genuine reversal of the Earth's field in Triassic-Jurassic times, Geophys. J. R. Astron. Soc, vol.7, pp.23-39, 1962. ,
The palaeomagnetism of the Stormberg lavas of South Africa 2: The behaviour of the magnetic field during a reversal, Geophys. J. R. Astron. Soc, vol.7, pp.169-182, 1962. ,
