Conference papers
Agricultural control of Radopholus similis in banana and plantain plantations
Abstract : The nematode Radopholus Similis is the most significant parasitic nematode of the banana plant and the banana plantain plant in the world. R. Similis feeds on the root tissues and causes damages going from simple root lesions, reducing the crop yield, to the fall of seedlings. Because of these damages, R. Similis is one of the most regulated pests of plant but its control still implies toxic nematicides with limited efficiency and harmful ecological impact. Our global aim is to design more efficient and sustainable control strategies, including alternative methods to nematicides such as crop rotation or fallow practice. Our approach is based on a hybrid model describing the plant-nematode interactions over several cropping seasons. During the fallow, in the absence of host, the pest population undergoes a rapid decay. We formulate an optimisation problem to determine the fallow periods that maximise the multi-seasonal yield over a finite and fixed time horizon. Two cases are considered: a constant or variable fallow periods. The existence of an optimalsolution is proven and its location is computed. Numerical simulations are providedto illustrate our results.
Complete list of metadata
https://hal.inria.fr/hal-02139560
Contributor : Jean-Luc Gouzé Connect in order to contact the contributor
Submitted on : Wednesday, October 9, 2019 - 11:36:40 AM
Last modification on : Thursday, August 4, 2022 - 4:57:00 PM
Identifiers
  • HAL Id : hal-02139560, version 1
Citation
Israël Tankam Chedjou, Suzanne Touzeau, Ludovic Mailleret, Frédéric Grognard, Jean Jules Tewa. Agricultural control of Radopholus similis in banana and plantain plantations. BIOMATH 2019 - International Conference on Mathematical Methods and Models in Biosciences, Jun 2019, Bedlewo, Poland. ⟨hal-02139560⟩
Share
Metrics
Record views
116
Files downloads
35
