Weak and approximate curvatures of a measure: a varifold perspective - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Analysis Année : 2022
By revisiting the notion of generalized second fundamental form originally introduced by Hutchinson for a special class of integral varifolds, we define a weak curvature tensor that is particularly well-suited for being extended to general varifolds of any dimension and codimension through regularization. The resulting approximate second fundamental forms are defined not only for piecewise-smooth surfaces, but also for datasets of very general type (like, e.g., point clouds). We obtain explicitly computable formulas for both weak and approximate curvature tensors, we exhibit structural properties and prove convergence results, and lastly we provide some numerical tests on point clouds that confirm the generality and effectiveness of our approach.
SFF_2022.pdf (4.04 Mo) Télécharger le fichier
hal-02141391 , version 1 (27-12-2022)
Blanche Buet, Gian Paolo Leonardi, Simon Masnou. Weak and approximate curvatures of a measure: a varifold perspective. Nonlinear Analysis, 2022, 222, pp.112983. ⟨10.1016/j.na.2022.112983⟩. ⟨hal-02141391⟩
87 Consultations
28 Téléchargements
