Exponentially few RNA structures are designable
The problem of RNA design attempts to construct RNA sequences that performs a predefined biological function, identified by several additional constraints. One of the foremost objective of RNA design is that the designed RNA sequence should adopt a predefined target secondary structure preferentially to any alternative structure, according to a given metrics and folding model. It was observed in several works that some secondary structures are undesignable, i.e. no RNA sequence can fold into the target structure while satisfying some criterion measuring how preferential this folding is compared to alternative conformations. In this paper, we show that the proportion of designable secondary structures decreases exponentially with the size of the target secondary structure, for various popular combinations of energy models and design objectives. This exponential decay is, at least in part, due to the existence of undesignable motifs, which can be generically constructed, and jointly analyzed to yield asymptotic upper-bounds on the number of designable structures.
Bio-informatique [q-bio.QM]
