Stochastically forced cardiac bidomain model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastic Processes and their Applications Année : 2019
The bidomain system of degenerate reaction–diffusion equations is a well-established spatial model of electrical activity in cardiac tissue, with “reaction” linked to the cellular action potential and “diffusion” representing current flow between cells. The purpose of this paper is to introduce a “stochastically forced” version of the bidomain model that accounts for various random effects. We establish the existence of martingale (probabilistic weak) solutions to the stochastic bidomain model. The result is proved by means of an auxiliary nondegenerate system and the Faedo–Galerkin method. To prove convergence of the approximate solutions, we use the stochastic compactness method and Skorokhod–Jakubowski a.s. representations. Finally, via a pathwise uniqueness result, we conclude that the martingale solutions are pathwise (i.e., probabilistic strong) solutions.
hal-02142024 , version 1 (28-05-2019)
Mostafa Bendahmane, Kenneth Hvistendahl Karlsen. Stochastically forced cardiac bidomain model. Stochastic Processes and their Applications, In press, 129 (12), pp.5312-5363. ⟨10.1016/j.spa.2019.03.001⟩. ⟨hal-02142024⟩
42 Consultations
0 Téléchargements
