A Virtual Element Method for a Nonlocal FitzHugh-Nagumo Model of Cardiac Electrophysiology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IMA Journal of Numerical Analysis Année : 2019
We present a virtual element method (VEM) for a nonlocal reaction–diffusion system of the cardiac electric field. For this system, we analyze an H1-conforming discretization by means of VEM that can make use of general polygonal meshes. Under standard assumptions on the computational domain, we establish the convergence of the discrete solution by considering a series of a priori estimates and by using a general Lp compactness criterion. Moreover, we obtain optimal order space-time error estimates in the L2 norm. Finally, we report some numerical tests supporting the theoretical results.
hal-02142031 , version 1 (28-05-2019)
Veronica Anaya, Mostafa Bendahmane, David Mora, Mauricio Sepulveda. A Virtual Element Method for a Nonlocal FitzHugh-Nagumo Model of Cardiac Electrophysiology. IMA Journal of Numerical Analysis, inPress, ⟨10.1093/imanum/drz001⟩. ⟨hal-02142031⟩
71 Consultations
0 Téléchargements
