Variance computation of modal parameter estimates from UPC subspace identification, IOMAC -7th International Operational Modal Analysis Conference, 2017. ,
Structural health monitoring with statistical methods during progressive damage test of S101 bridge. Engineering Structures, vol.69, pp.183-193, 2014. ,
Uncertainty quantification for modal parameters from stochastic subspace identification on multi-setup measurements, Mechanical Systems and Signal Processing, vol.36, p.2013 ,
Multi-order covariance computation for estimates in stochastic subspace identification using QR decompositions, IFAC Proceedings Volumes, vol.47, pp.9498-9503, 2014. ,
Efficient multi-order uncertainty computation for stochastic subspace identification, Mechanical Systems and Signal Processing, vol.38, pp.346-366, 2013. ,
The modal assurance criterion (MAC): Twenty years of use and abuse, Journal of Sound and Vibration, vol.37, 2003. ,
An eigensystem realization algorithm for modal parameter identification and model reduction, Journal of Guidance, Control, and Dynamics, vol.8, pp.620-627, 1985. ,
A new chi-square approximation to the distribution of nonnegative definite quadratic forms in non-central normal variables, Computational Statistics and Data Analysis, vol.53, issue.4, pp.853-856, 2009. ,
Variance estimation of modal parameters from output-only and input/output subspace-based system identification, Journal of Sound and Vibration, vol.379, pp.1-27, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01328435
A consistent-mode indicator for the eigensystem realization algorithm, Journal of Guidance Control and Dynamics, vol.16, 1993. ,
Uncertainty calculation in (operational) modal analysis. Mechanical Systems and Signal Processing, vol.21, pp.2359-2373, 2007. ,
Uncertainty quantification in operational modal analysis with stochastic subspace identification: Validation and applications, Mechanical Systems and Signal Processing, pp.13-30, 2016. ,
Uncertainty bounds on modal parameters obtained from stochastic subspace identification, Mechanical Systems and Signal Processing, vol.22, issue.4, pp.948-969, 2008. ,
DOI : 10.1016/j.ymssp.2007.10.009
Extensions of the mac criterion to complex modes, ISMA 2010 International Conference on Noise and Vibration Engineering, 2010. ,
