Convergence of descent methods for semi-algebraic and tame problems: proximal algorithms, forward-backward splitting, and regularized Gauss-Seidel methods, Mathematical Programming, vol.137, issue.1, pp.91-129, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00790042
Sparsity Constrained Nonlinear Optimization: Optimality Conditions and Algorithms, SIAM Journal on Optimization, vol.23, issue.3, pp.1480-1509, 2013. ,
, On the Minimization Over Sparse Symmetric Sets: Projections, Optimality Conditions, and Algorithms. Mathematics of Operations Research, vol.41, pp.196-223, 2016.
Proximal Mapping for Symmetric Penalty and Sparsity, SIAM Journal on Optimization, vol.28, issue.1, pp.496-527, 2018. ,
Iterative hard thresholding for compressed sensing, vol.27, pp.265-274, 2009. ,
Exact Sparse Approximation Problems via MixedInteger Programming: Formulations and Computational Performance, IEEE Transactions on Signal Processing, vol.64, issue.6, pp.1405-1419, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01254856
Better Subset Regression Using the Nonnegative Garrote, Technometrics, vol.37, issue.4, pp.373-384, 1995. ,
Robust uncertainty principles: exact signal reconstruction from highly incomplete frequency information, IEEE Transactions on Information Theory, vol.52, issue.2, pp.489-509, 2006. ,
Enhancing Sparsity by Reweighted 1 Minimization, Journal of Fourier Analysis and Applications, vol.14, issue.5, pp.877-905, 2008. ,
An unbiased approach to compressed sensing, 2018. ,
On Convex Envelopes and Regularization of Non-convex Functionals Without Moving Global Minima, Journal of Optimization Theory and Applications, vol.183, issue.1, pp.66-84, 2019. ,
Orthogonal least squares learning algorithm for radial basis function networks, IEEE Transactions on Neural Networks, vol.2, issue.2, pp.302-309, 1991. ,
A Majorize-Minimize Subspace Approach for 2 ? 0 Image Regularization, SIAM Journal on Imaging Sciences, vol.6, issue.1, pp.563-591, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00789962
Subspace Pursuit for Compressive Sensing Signal Reconstruction, IEEE Transactions on Information Theory, vol.55, issue.5, pp.2230-2249, 2009. ,
For most large underdetermined systems of linear equations the minimal 1 -norm solution is also the sparsest solution, Communications on Pure and Applied Mathematics, vol.59, issue.6, pp.797-829, 2006. ,
Stability of the Minimizers of Least Squares with a Non-Convex Regularization, Part I: Local Behavior. Applied Mathematics and Optimization, vol.53, issue.2, pp.185-208, 2006. ,
Stability of the Minimizers of Least Squares with a Non-Convex Regularization, Part II: Global Behavior. Applied Mathematics and Optimization, vol.53, issue.3, pp.259-277, 2006. ,
Variable Selection via Nonconcave Penalized Likelihood and Its Oracle Properties, Journal of the American Statistical Association, vol.96, issue.456, pp.1348-1360, 2001. ,
Hard Thresholding Pursuit: An Algorithm for Compressive Sensing, SIAM Journal on Numerical Analysis, vol.49, issue.6, pp.2543-2563, 2011. ,
Sparsest solutions of underdetermined linear systems via q -minimization for 0<q ? 1. Applied and Computational Harmonic Analysis, vol.26, pp.395-407, 2009. ,
Constrained restoration and the recovery of discontinuities, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.3, pp.367-383, 1992. ,
Sparse signal reconstruction from limited data using FOCUSS: A reweighted minimum norm algorithm, IEEE Transactions on Signal Processing, pp.600-616, 1997. ,
Bayesian pursuit algorithms, 18th European Signal Processing Conference, pp.1474-1478, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00539109
Orthogonal Matching Pursuit with Replacement, Advances in Neural Information Processing Systems, vol.24, pp.1215-1223, 2011. ,
Matching pursuits with time-frequency dictionaries, IEEE Transactions on Signal Processing, vol.41, issue.12, pp.3397-3415, 1993. ,
How to Globally Solve Non-convex Optimization Problems Involving an Approximate 0 Penalization, IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.5601-5605, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02196878
CoSaMP: Iterative signal recovery from incomplete and inaccurate samples, Applied and Computational Harmonic Analysis, vol.26, issue.3, pp.301-321, 2009. ,
Djermoune. NP-hardness of 0 minimization problems: revision and extension to the non-negative setting, International Conference on Sampling Theory and Applications (SampTa), 2019. ,
Analysis of the Recovery of Edges in Images and Signals by Minimizing Nonconvex Regularized LeastSquares, Multiscale Modeling & Simulation, vol.4, issue.3, pp.960-991, 2005. ,
Bounds on the Minimizers of (nonconvex) Regularized Least-Squares, Scale Space and Variational Methods in Computer Vision, pp.496-507, 2007. ,
Solve exactly an under determined linear system by minimizing least squares regularized with an 0 penalty, Comptes Rendus Mathematique, vol.349, issue.21, pp.1145-1150, 2011. ,
Description of the Minimizers of Least Squares Regularized with 0 -norm. Uniqueness of the Global Minimizer, SIAM Journal on Imaging Sciences, vol.6, issue.2, pp.904-937, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00723812
Relationship between the optimal solutions of least squares regularized with 0 -norm and constrained by k-sparsity. Applied and Computational Harmonic, Analysis, vol.41, issue.1, pp.237-265, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-00944006
Analysis of Half-Quadratic Minimization Methods for Signal and Image Recovery, SIAM Journal on Scientific Computing, vol.27, issue.3, pp.937-966, 2005. ,
On Iteratively Reweighted Algorithms for Nonsmooth Nonconvex Optimization in Computer Vision, SIAM Journal on Imaging Sciences, vol.8, issue.1, pp.331-372, 2015. ,
Orthogonal matching pursuit: recursive function approximation with applications to wavelet decomposition, Proceedings of 27th Asilomar Conference on Signals, Systems and Computers, vol.1, pp.40-44, 1993. ,
Sparse learning via Boolean relaxations, Mathematical Programming, vol.151, issue.1, pp.63-87, 2015. ,
Euclid in a Taxicab: Sparse Blind Deconvolution with Smoothed 1 / 2 Regularization, IEEE Signal Processing Letters, vol.22, issue.5, pp.539-543, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01328398
Sparse Regularization via Convex Analysis, IEEE Transactions on Signal Processing, vol.65, issue.17, pp.4481-4494, 2017. ,
Sparse Signal Approximation via Nonseparable Regularization, IEEE Transactions on Signal Processing, vol.65, issue.10, pp.2561-2575, 2017. ,
A Continuous Exact 0 Penalty (CEL0) for Least Squares Regularized Problem, SIAM Journal on Imaging Sciences, vol.8, issue.3, pp.1607-1639, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01102492
A Unified View of Exact Continuous Penalties for 2 -0 Minimization, SIAM Journal on Optimization, vol.27, issue.3, pp.2034-2060, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01267701
From Bernoulli-Gaussian Deconvolution to Sparse Signal Restoration, IEEE Transactions on Signal Processing, vol.59, issue.10, pp.4572-4584, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00443842
Homotopy Based Algorithms for 0 -Regularized Least-Squares, IEEE Transactions on Signal Processing, vol.63, issue.13, pp.3301-3316, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00948313
Greedy approximation, Acta Numerica, vol.17, pp.235-409, 2008. ,
Greed is good: algorithmic results for sparse approximation, IEEE Transactions on Information Theory, vol.50, issue.10, pp.2231-2242, 2004. ,
Just relax: convex programming methods for identifying sparse signals in noise, IEEE Transactions on Information Theory, vol.52, issue.3, pp.1030-1051, 2006. ,
A Survey on Nonconvex Regularization-Based Sparse and Low-Rank Recovery in Signal Processing, Statistics, and Machine Learning, IEEE Access, vol.6, pp.69883-69906, 2018. ,
Nearly unbiased variable selection under minimax concave penalty. The Annals of Statistics, vol.38, pp.894-942, 2010. ,
On optimal solutions of the constrained 0 regularization and its penalty problem, verse Problems, vol.33, p.25010, 2017. ,
Multi-stage Convex Relaxation for Learning with Sparse Regularization, Advances in Neural Information Processing Systems 21, pp.1929-1936, 2009. ,
The Adaptive Lasso and Its Oracle Properties, Journal of the American Statistical Association, vol.101, issue.476, pp.1418-1429, 2006. ,
