Visual Debugging of Behavioural Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present the CLEAR visualizer tool, which supports the debugging task of behavioural models being analyzed using model checking techniques. The tool provides visualization techniques for simplifying the comprehension of counterexamples by highlighting some specific states in the model where a choice is possible between executing a correct behaviour or falling into an erroneous part of the model. Our tool was applied successfully to many case studies and allowed us to visually identify several kinds of typical bugs. Video URL: https://youtu.be/nJLOnRaPe1A.
main.pdf (5.7 Mo) Télécharger le fichier
hal-02145535 , version 1 (03-06-2019)
Gianluca Barbon, Vincent Leroy, Gwen Salaün, Emmanuel Yah. Visual Debugging of Behavioural Models. ICSE 2019 - IEEE/ACM 41st International Conference on Software Engineering: Companion Proceedings, May 2019, Montreal, Canada. pp.107-110, ⟨10.1109/ICSE-Companion.2019.00050⟩. ⟨hal-02145535⟩
161 Consultations
154 Téléchargements
