Table-Based versus Shift-And-Add constant multipliers for FPGAs
The multiplication by a constant is a frequently used operation. To implement it on Field Programmable Gate Arrays (FPGAs), the state of the art offers two completely different methods: one relying on bit shifts and additions/subtractions, and another one using look-up tables and additions. So far, it was unclear which method performs best for a given constant and input/output data types. The main contribution of this work is a thorough comparison of both methods in the main application contexts of constant multiplication: filters, signalprocessing transforms, and elementary functions. Most of the
previous state of the art addresses multiplication by an integer constant. This work shows that, in most of these application contexts, a formulation of the problem as the multiplication by a real constant allows for more efficient architectures. Another contribution is a novel extension of the shift-and-add method to real constants. For that, an integer linear programming (ILP) formulation is proposed, which truncates each component in the shift-and-add network to a minimum necessary word size that is aligned with the approximation error of the coefficient. All methods are implemented within the open-source FloPoCo framework.
