Impact of rpoS deletion on Escherichia coli biofilms, Appl Environ Microbiol, vol.65, pp.4285-4287, 1999. ,
Regulation of Salmonella enterica serovar typhimurium invasion genes by csrA, Infect Immun, vol.68, pp.6790-6797, 2000. ,
Methods and advances in metabolic flux analysis: a mini-review, J Ind Microbiol Biotechnol, vol.42, pp.317-325, 2015. ,
A rapid and sensitive method for the quantitation of microgram quantities of protein utilizing the principle of protein-dye binding, Anal Biochem, vol.72, pp.248-254, 1976. ,
An insight into the role of phosphotransacetylase (pta) and the acetate/acetyl-CoA node in Escherichia coli, Microb Cell Fact, vol.8, p.54, 2009. ,
Molecular basis for the wide range of affinity found in Csr/Rsm protein-RNA recognition, Nucleic Acids Res, vol.42, pp.5332-5346, 2014. ,
Circuitry linking the Csr and stringent response global regulatory systems, Mol Microbiol, vol.80, pp.1561-1580, 2011. ,
Intuitive visualization and analysis of multi-omics data and application to Escherichia coli carbon metabolism, PloS ONE, vol.6, p.21318, 2011. ,
Physiological and molecular timing of the glucose to acetate transition in Escherichia coli, Metabolites, vol.3, pp.820-837, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-02146740
Dual role of transcription and transcript stability in the regulation of gene expression in Escherichia coli cells cultured on glucose at different growth rates, Nucleic Acids Res, vol.42, pp.2460-2472, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-02129879
Quantitative analysis of flux regulation through hierarchical regulation analysis, Methods Enzymol, vol.500, pp.571-595, 2011. ,
Molecular physiology of sugar catabolism in Lactococcus lactis IL1403, J Bacteriol, vol.183, pp.3817-3824, 2001. ,
A genome-scale metabolic reconstruction for Escherichia coli K-12 MG1655 that accounts for 1260 ORFs and thermodynamic information, Mol Syst Biol, vol.3, 2007. ,
Metabolic flux profiling of Escherichia coli mutants in central carbon metabolism using GC-MS, Eur J Biochem, vol.270, pp.880-891, 2003. ,
Systems biology of microbial metabolism, Curr Opin Microbiol, vol.13, pp.337-343, 2010. ,
Flux analysis and control of the central metabolic pathways in Escherichia coli, FEMS Microbiol Rev, vol.19, pp.85-116, 1996. ,
, Phosphoglucomutase from Yeast. Methods Enzymol, vol.89, pp.599-605, 1982.
Transcriptome meets metabolome: hierarchical and metabolic regulation of the glycolytic pathway, Mol Syst Biol, vol.6, pp.169-171, 2001. ,
Improving metabolic flux predictions using absolute gene expression data, BMC Syst Biol, vol.6, p.73, 2012. ,
The product of the pleiotropic Escherichia coli gene csrA modulates glycogen biosynthesis via effects on mRNA stability, J Bacteriol, vol.177, pp.2663-2672, 1995. ,
The effects of alternate optimal solutions in constraint-based genomescale metabolic models, Metab Eng, vol.5, pp.264-276, 2003. ,
Characterization of EvaGreen and the implication of its physicochemical properties for qPCR applications, BMC Biotechnol, vol.7, p.76, 2007. ,
Manipulation of the carbon storage regulator system for metabolite remodeling and biofuel production in Escherichia coli, Microb Cell Fact, vol.11, p.79, 2012. ,
Accumulation of glucose 6-phosphate or fructose 6-phosphate is responsible for destabilization of glucose transporter mRNA in Escherichia coli, J Biol Chem, pp.15608-15614, 2003. ,
Systematic phenome analysis of Escherichia coli multiple-knockout mutants reveals hidden reactions in central carbon metabolism, Mol Syst Biol, vol.5, p.306, 2009. ,
Active starvation responses mediate antibiotic tolerance in biofilms and nutrient-limited bacteria, Science, vol.334, pp.982-986, 2011. ,
URL : https://hal.archives-ouvertes.fr/pasteur-00722468
A simplified procedure for a rapid and reliable assay of both glycogen and trehalose in whole yeast cells, Anal Biochem, vol.248, pp.186-188, 1997. ,
Global metabolic regulation analysis for Escherichia coli K12 based on protein expression by 2-dimensional electrophoresis and enzyme activity measurement, Appl Microbiol Biotechnol, vol.61, pp.163-178, 2003. ,
The carbon storage regulator (CSR) system exerts a nutrientspecific control over central metabolism in Escherichia coli strain Nissle 1917, PloS ONE, vol.8, p.66386, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-02131871
The small RNA SgrS controls sugar-phosphate accumulation by regulating multiple PTS genes, Nucleic Acids Res, vol.39, pp.3806-3819, 2011. ,
Identification and molecular characterization of csrA, a pleiotropic gene from Escherichia coli that affects glycogen biosynthesis, gluconeogenesis, cell size, and surface properties, J Bacteriol, vol.175, pp.4744-4755, 1993. ,
Posttranscriptional regulation on a global scale: form and function of Csr/Rsm systems, Environ Microbiol, vol.15, pp.313-324, 2013. ,
Pleiotropic regulation of central carbohydrate metabolism in Escherichia coli via the gene csrA, J Biol Chem, vol.270, pp.29096-29104, 1995. ,
Deletion of the Escherichia coli crp gene, J Bacteriol, vol.122, pp.338-340, 1975. ,
Metabolic flux ratio analysis of genetic and environmental modulations of Escherichia coli central carbon metabolism, J Bacteriol, vol.181, pp.6679-6688, 1999. ,
Quantitative prediction of cellular metabolism with constraint-based models: the COBRA Toolbox, Nat Protoc, vol.6, pp.1290-1307, 2011. ,
The ribonucleoprotein Csr network, Int J Mol Sci, vol.14, pp.22117-22131, 2013. ,
Regulation systems of bacteria such as Escherichia coli in response to nutrient limitation and environmental stresses, Metabolites, vol.4, pp.1-35, 2014. ,
A model of yeast glycolysis based on a consistent kinetic characterisation of all its enzymes, FEBS Lett, vol.587, pp.2832-2841, 2013. ,
Development and application of a differential method for reliable metabolome analysis in Escherichia coli, Anal Biochem, vol.386, pp.9-19, 2009. ,
Conditional essentiality of the csrA gene in Escherichia coli, J Bacteriol, vol.191, pp.1722-1724, 2009. ,
Post-transcriptional global regulation by CsrA in bacteria, Cell Mol Life Sci, vol.67, pp.2897-2908, 2010. ,
Physiological consequences of small RNA-mediated regulation of glucose-phosphate stress, Curr Opin Microbiol, vol.10, pp.146-151, 2007. ,
Environmental and physiological factors affecting the succinate product ratio during carbohydrate fermentation by Actinobacillus sp. 130Z, Arch Microbiol, vol.167, pp.332-342, 1997. ,
Global regulatory mutations in csrA and rpoS cause severe central carbon stress in Escherichia coli in the presence of acetate, J Bacteriol, vol.182, pp.1632-1640, 2000. ,
Global impact of sdiA amplification revealed by comprehensive gene expression profiling of Escherichia coli, J Bacteriol, vol.183, pp.2265-2272, 2001. ,
CsrA activates flhDC expression by protecting flhDC mRNA from RNase E-mediated cleavage, Mol Microbiol, vol.87, pp.851-866, 2013. ,
DOI : 10.1111/mmi.12136
URL : https://onlinelibrary.wiley.com/doi/pdf/10.1111/mmi.12136
Coordinate genetic regulation of glycogen catabolism and biosynthesis in Escherichia coli via the csrA gene product, J Bacteriol, vol.178, pp.1012-1017, 1996. ,
, Molecular Microbiology, vol.00, pp.0-00, 2016.
