Properties of Tight Frames that are Regular Schemes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Cryptography and Communications - Discrete Structures, Boolean Functions and Sequences Année : 2020
Finite frames are sequences of vectors in finite dimensional Hilbert spaces that play a key role in signal processing and coding theory. In this paper, we study the class of tight unit-norm frames for $Cd$ that also form regular schemes, which we call tight regular schemes (TRS). Many common frames that arise in applications such as equiangular tight frames and mutually unbiased bases fall in this class. We investigate characteristic properties of TRSs and prove that for many constructions, they are intimately connected to weighted 1-designs—arising from cubature rules for integrals over spheres in $Cd$—with weights dependent on the Voronoi regions of each frame element. Aided by additional numerical evidence, we conjecture that all TRSs in fact satisfy this property.
CCDS_EGAN_2019.pdf (283.69 Ko) Télécharger le fichier
hal-02148974 , version 1 (06-06-2019)
Malcolm Egan. Properties of Tight Frames that are Regular Schemes. Cryptography and Communications - Discrete Structures, Boolean Functions and Sequences , 2020, 12, pp.499-510. ⟨10.1007/s12095-019-00378-2⟩. ⟨hal-02148974⟩
91 Consultations
240 Téléchargements
