A New Ranking Function for Polynomial Selection in the Number Field Sieve - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
This article explains why the classical Murphy-E ranking function might fail to correctly rank polynomial pairs in the Number Field Sieve, and proposes a new ranking function.
rootsieve-revised.pdf (335.46 Ko) Télécharger le fichier
hal-02151093 , version 1 (07-06-2019)
hal-02151093 , version 2 (26-08-2019)
hal-02151093 , version 3 (04-09-2019)
hal-02151093 , version 4 (17-06-2020)
  • HAL Id : hal-02151093 , version 2
Nicolas David, Paul Zimmermann. A New Ranking Function for Polynomial Selection in the Number Field Sieve. 2019. ⟨hal-02151093v2⟩
430 Consultations
561 Téléchargements
