Model Predictive Control, Cost Controllability, and Homogeneity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2020
We are concerned with the design of Model Predictive Control (MPC) schemes such that asymptotic stability of the resulting closed loop is guaranteed even if the linearization at the desired set point fails to be stabilizable. Therefore, we propose to construct the stage cost based on the homogeneous approximation and rigorously show that applying MPC yields an asymp-totically stable closed-loop behavior if the homogeneous approximation is asymptotically null controllable. To this end, we verify cost controllability-a condition relating the current state, the stage cost, and the growth of the value function w.r.t. time-for this class of systems in order to provide stability and performance guarantees for the proposed MPC scheme without stabilizing terminal costs or constraints.
homogeneity_article-ArXiv.pdf (269.61 Ko) Télécharger le fichier
hal-02151402 , version 1 (08-06-2019)
hal-02151402 , version 2 (09-12-2019)
Jean-Michel Coron, Lars Grüne, Karl Worthmann. Model Predictive Control, Cost Controllability, and Homogeneity. SIAM Journal on Control and Optimization, 2020, 58 (5), pp.2979-2996. ⟨10.1137/19M1265995⟩. ⟨hal-02151402v2⟩
186 Consultations
748 Téléchargements
