Detection of Abrupt Changes: Theory And Application, 1993. ,
URL : https://hal.archives-ouvertes.fr/hal-00008518
Combining the Generalized Likelihood Ratio Test and kl-UCB for Non-Stationary Bandits, 2019. ,
The large-sample distribution of the likelihood ratio for testing composite hypotheses, The Annals of Mathematical Statistics, vol.9, issue.1, pp.60-62, 1938. ,
Using the Generalized Likelihood Ratio Statistic for Sequential Detection of a Change Point, The Annals of Statistics, pp.255-271, 1995. ,
Sequential change-point detection when the pre-and post-change parameters are unknown, Sequential Analysis, vol.29, 2010. ,
DOI : 10.1080/07474941003741078
Sequential change-point detection: Laplace concentration of scan statistics and non-asymptotic delay bounds, 2019. ,
Kullback-Leibler Upper Confidence Bounds For Optimal Sequential Allocation, Annals of Statistics, vol.41, issue.3, 2013. ,
Mixture Martingales Revisited with Applications to Sequential Tests and Confidence Intervals, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01886612
Discounted UCB, 2nd PASCAL Challenges Workshop, 2006. ,
On Upper-Confidence Bound Policies For Switching Bandit Problems, 2011. ,
DOI : 10.1007/978-3-642-24412-4_16
A Change-Detection based Framework for Piecewise-stationary Multi-Armed Bandit Problem, 2018. ,
Nearly Optimal Adaptive Procedure for Piecewise-Stationary Bandit: a Change-Point Detection Approach, 2019. ,
SMPyBandits: an Open-Source Research Framework for Single and Multi-Players Multi-Arms Bandits (MAB) Algorithms in Python, 2018. ,
