Linking of Antitumor trans NHC-Pt(II) Complexes to G-Quadruplex DNA Ligand for Telomeric Targeting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bioconjugate Chemistry Année : 2016
G-quadruplex structures (G4) are promising anticancer-ous targets. A great number of small molecules targeting these structures have already been identified through biophysical methods. In cellulo, some of them are able to target either telomeric DNA and/or some sequences involved in oncogene promotors, both resulting in cancer cell death. However, only a few of them are able to bind to these structures G4 irreversibly. Here we combine within the same molecule the G4-binding agent PDC (pyridodicarboxamide) with a N-heterocyclic carbene−platinum complex NHC-Pt already identified for its antitumor properties. The resulting conjugate platinum complex NHC-Pt-PDC stabilizes strongly G-quadruplex structures in vitro, with affinity slightly affected as compared to PDC. In addition, we show that the new conjugate binds preferentially and irreversibly the quadruplex form of the human telomeric sequence with a profile in a way different from that of NHC-Pt thereby indicating that the platination reaction is oriented by stacking of the PDC moiety onto the G4-structure. In cellulo, NHC-Pt-PDC induces a significant loss of TRF2 from telomeres that is considerably more important than the effect of its two components alone, PDC and NHC-Pt, respectively.
BC BETZER - version HAL.pdf (1.72 Mo) Télécharger le fichier
hal-02152296 , version 1 (20-09-2019)
Jean-François Betzer, Frédérick Nuter, Mélanie Chtchigrovsky, Florian Hamon, Guillaume Kellermann, et al.. Linking of Antitumor trans NHC-Pt(II) Complexes to G-Quadruplex DNA Ligand for Telomeric Targeting. Bioconjugate Chemistry, 2016, 27 (6), pp.1456-1470. ⟨10.1021/acs.bioconjchem.6b00079⟩. ⟨hal-02152296⟩
126 Consultations
159 Téléchargements
