Investigating Placement Challenges in Edge Infrastructures through a Common Simulator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2019
Efficiently scheduling computational jobs with data-sets dependencies is one of the most important challenges of fog/edge computing infrastruc-tures. Although several strategies have been proposed, they have been evaluated through ad-hoc simulator extensions that are, when available, usually not maintained. This is a critical problem because it prevents researchers to-easily-conduct fair evaluations to compare each proposal. In this short paper, we propose to address this limitation by presenting the first elements of a common simulator. More precisely, we describe an ongoing project involving academics and a high-tech company that aims at delivering a dedicated tool to evaluate scheduling policies in edge computing infrastructures. This tool enables the community to simulate various policies and to easily customize researchers/engineers' use-cases, adding new functionalities if needed. The implementation has been built upon the Batsim/SimGrid toolkit, which has been designed to evaluate batch scheduling strategies in various distributed infrastruc-tures. Although the complete validation of the simulation toolkit is still ongoing , we demonstrate its relevance by studying different scheduling strategies on top of a simulated version of the Qarnot Computing platform , a production edge infrastructure based on smart heaters.
main.pdf (459.08 Ko) Télécharger le fichier
hal-02153203 , version 1 (12-06-2019)
hal-02153203 , version 2 (16-07-2019)
hal-02153203 , version 3 (20-02-2020)
hal-02153203 , version 4 (24-02-2020)
hal-02153203 , version 5 (25-05-2020)
  • HAL Id : hal-02153203 , version 1
Adwait Bauskar, Anderson da Silva, Adrien Lebre, Clement Mommessin, Pierre Neyron, et al.. Investigating Placement Challenges in Edge Infrastructures through a Common Simulator. [Research Report] 9282, DATAMOVE; STACS. 2019, pp.1-16. ⟨hal-02153203v1⟩
618 Consultations
468 Téléchargements
