Investigating Placement Challenges in Edge Infrastructures through a Common Simulator (extended version) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Scheduling computational jobs with data-sets dependencies is an important challenge of edge computing infrastructures. Although several strategies have been proposed, they have been evaluated through ad-hoc simulator extensions that are, when available, usually not maintained. This is a critical problem because it prevents researchers to-easily-perform fair comparisons between different proposals. In this paper, we propose to address this limitation by presenting a simulation engine dedicated to the evaluation and comparison of scheduling and data movement policies for edge computing use-cases. Built upon the Batsim/SimGrid toolkit, our tool includes a plug-in system that allows researchers to add new models in order to cope with the diversity of edge computing devices. Moreover, it includes an injector that allows the simulator to replay a series of events captured in real infrastructures. We demonstrate the relevance of such a simulation toolkit by studying 2 scheduling strategies with 4 data movement policies on top of a simulated version of the Qarnot Computing platform, a production edge infrastructure based on smart heaters. We chose this use-case as it illustrates the heterogeneity as well as the uncertainties of edge infrastructures. Our ultimate goal is to gather industry and academics around a common simulator so that efforts made by one group can be factorized by others.
RR-9282.pdf (970.14 Ko) Télécharger le fichier
hal-02153203 , version 1 (12-06-2019)
hal-02153203 , version 2 (16-07-2019)
hal-02153203 , version 3 (20-02-2020)
hal-02153203 , version 4 (24-02-2020)
hal-02153203 , version 5 (25-05-2020)
  • HAL Id : hal-02153203 , version 2
Adwait Bauskar, Anderson da Silva, Adrien Lebre, Clement Mommessin, Pierre Neyron, et al.. Investigating Placement Challenges in Edge Infrastructures through a Common Simulator (extended version). 2020. ⟨hal-02153203v2⟩
618 Consultations
468 Téléchargements
