Reports
Investigating Placement Challenges in Edge Infrastructures through a Common Simulator (extended version)
Abstract : Scheduling computational jobs with data-sets dependencies is an important challenge of edge computing infrastructures. Although several strategies have been proposed, they have been evaluated through ad-hoc simulator extensions that are, when available, usually not maintained. This is a critical problem because it prevents researchers to-easily-perform fair comparisons between different proposals. In this paper, we propose to address this limitation by presenting a simulation engine dedicated to the evaluation and comparison of scheduling and data movement policies for edge computing use-cases. Built upon the Batsim/SimGrid toolkit, our tool includes a plug-in system that allows researchers to add new models in order to cope with the diversity of edge computing devices. Moreover, it includes an injector that allows the simulator to replay a series of events captured in real infrastructures. We demonstrate the relevance of such a simulation toolkit by studying 2 scheduling strategies with 4 data movement policies on top of a simulated version of the Qarnot Computing platform, a production edge infrastructure based on smart heaters. We chose this use-case as it illustrates the heterogeneity as well as the uncertainties of edge infrastructures. Our ultimate goal is to gather industry and academics around a common simulator so that efforts made by one group can be factorized by others.
Complete list of metadatas
Cited literature [27 references]  Display  Hide  Download
https://hal.inria.fr/hal-02153203
Contributor : Clement Mommessin <>
Submitted on : Monday, February 24, 2020 - 4:38:15 PM
Last modification on : Friday, April 10, 2020 - 3:08:02 PM
File
RR-9282.pdf
Identifiers
  • HAL Id : hal-02153203, version 4
Citation
Adwait Bauskar, Anderson da Silva, Adrien Lebre, Clement Mommessin, Pierre Neyron, et al.. Investigating Placement Challenges in Edge Infrastructures through a Common Simulator (extended version). [Research Report] RR-9282, INRIA. 2020. ⟨hal-02153203v4⟩
Share
Metrics
Record views
60
Files downloads
219
