Theoretical analysis and control results for the fitzhugh-nagumo equation, Electronic Journal of Differential Equations, vol.164, 2008. ,
Sparse optimal control of the schlögl and fitzhugh-nagumo systems, Computational Methods in Applied Mathematics, vol.13, issue.4, pp.415-442, 2013. ,
Optimal control of the bidomain system (iii): Existence of minimizers and first-order optimality conditions, ESAIM: Mathematical Modelling and Numerical Analysis, vol.47, issue.4, pp.1077-1106, 2013. ,
Numerical solution for optimal control of the reaction-diffusion equations in cardiac electrophysiology, Computational Optimization and Applications, vol.49, issue.1, pp.149-178, 2011. ,
Primal-dual active set strategy for large scale optimization of cardiac defibrillation, Applied Mathematics and Computation, vol.292, pp.178-193, 2017. ,
A 3d boundary optimal control for the bidomain-bath system modeling the thoracic shock therapy for cardiac defibrillation, Journal of Mathematical Analysis and Applications, vol.437, issue.2, pp.972-998, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01261547
Parameter identification for a non-differentiable ionic model used in cardiac electrophysiology, Applied Mathematical Sciences, vol.9, issue.150, pp.7483-7507, 2015. ,
On the identification of multiple space dependent ionic parameters in cardiac electrophysiology modelling, Inverse Problems, vol.34, issue.3, p.35005, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01567714
Ionic parameters identification of an inverse problem of strongly coupled pdes system in cardiac electrophysiology using carleman estimates, Math. Model. Nat. Phenom, vol.14, issue.2, p.202, 2019. ,
Estimation of cardiac conductivities in ventricular tissue by a variational approach, Inverse Problems, vol.31, issue.11, p.115001, 2015. ,
Inverse problem of electrocardiography: Estimating the location of cardiac ischemia in a 3d realistic geometry, International Conference on Functional Imaging and Modeling of the Heart, pp.393-401, 2015. ,
On the use of the resting potential and level set methods for identifying ischemic heart disease: An inverse problem, Journal of computational physics, vol.220, issue.2, pp.772-790, 2007. ,
Parameters estimation approach for the mea/hipsc-cm asaays, Computing in Cardiology (CinC), pp.1-4, 2017. ,
A quantitative description of membrane current and its application to conduction and excitation in nerve, The Journal of Physiology, vol.117, issue.4, pp.500-544, 1952. ,
Mathematical Cardiac Electrophysiology, 2014. ,
A model of the ventricular cardiac action potential: Depolarization, repolarization, and their interaction, Circulation Research, vol.68, issue.6, pp.1501-1526, 1991. ,
Reconstruction of the action potential of ventricular myocardial fibres, The Journal of Physiology, vol.268, issue.1, pp.177-210, 1977. ,
Reaction-diffusion systems for the macroscopic bidomain model of the cardiac electric field, Nonlinear Analysis: Real World Applications, vol.10, pp.849-868, 2009. ,
Decoupled time-marching schemes in computational cardiac electrophysiology and ecg numerical simulation, Mathematical biosciences, vol.226, issue.1, pp.58-75, 2010. ,
