Recent advances in nonlinear passive vibration isolators, J. Sound Vib, vol.314, issue.3, pp.371-452, 2008. ,
DOI : 10.1016/j.jsv.2008.01.014
Device for damping vibrations of bodies ,
Nonlinear vibration absorber coupled to a nonlinear primary system: a tuning methodology, J. Sound Vib, vol.326, issue.3, pp.780-793, 2009. ,
Nonlinear generalization of den hartog's equal-peak method, Mech. Syst. Signal Process, pp.17-28, 2015. ,
DOI : 10.1016/j.ymssp.2014.08.009
URL : http://arxiv.org/pdf/1604.03868
, Nonlinear Targeted Energy Transfer in Mechanical and Structural Systems, Solid Mechanics and Its Applications, 2008.
Nonlinear energy pumping under transient forcing with strongly nonlinear coupling: theoretical and experimental results, J. Sound Vib, vol.300, issue.3, pp.522-551, 2007. ,
DOI : 10.1016/j.jsv.2006.06.074
URL : https://hal.archives-ouvertes.fr/hal-00815136
Passive control of aeroelastic instability in a long span bridge model prone to coupled flutter using targeted energy transfer, J. Sound Vib, vol.330, issue.11, pp.2580-2595, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00815198
Targeted energy transfer in systems with non-polynomial nonlinearity, J. Sound Vib, vol.315, issue.3, pp.732-745, 2008. ,
DOI : 10.1016/j.jsv.2007.12.024
Targeted energy transfer under harmonic forcing with a vibro-impact nonlinear energy sink: Analytical and experimental developments, J. Vib. Acoust, vol.137, issue.3, 2015. ,
DOI : 10.1115/1.4029285
URL : https://hal.archives-ouvertes.fr/hal-01820057
, Stephen Timoshenko 60th Anniversary, 1938.
Nonlinear aspects of the performance of centrifugal pendulum vibration absorbers, ASME, J. Eng. Industry, vol.86, pp.257-263, 1964. ,
Effects of nonlinearities and damping on the dynamic response of a centrifugal pendulum absorber, ASME, J. Vib. Acoust, vol.114, pp.305-311, 1992. ,
Brachistochrone and tautochrone curves for rolling bodies, Am. J. Phys, vol.14, pp.249-252, 1946. ,
DOI : 10.1119/1.1990827
, Horologuium oscilatorium sive de motu pendularium, p.1673
Tautochronic bifilar pendulum torsion absorbers for reciprocating engines, J. Sound Vib, vol.159, pp.251-277, 1992. ,
DOI : 10.1016/0022-460x(92)90035-v
, Nonlinear Oscillations, 1979.
Computation of Nonlinear Normal Modes through Shooting and Pseudo-Arclength Computation, pp.215-250, 2014. ,
A comparative study of the harmonic balance method and the orthogonal collocation method on stiff nonlinear systems, J. Sound Vib, vol.333, issue.12, pp.2554-2567, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01065672
Auto-07p: continuation and bifurcation software for ordinary differential equations, 1998. ,
Matcont: a matlab package for numerical bifurcation analysis of odes, ACM Trans. Math. Softw, vol.29, issue.2, pp.141-164, 2003. ,
A path-following technique via an asymptotic-numerical method, Comput. Struct, vol.53, issue.5, pp.1181-1192, 1994. ,
A principle of similarity for nonlinear vibration absorbers, Physica D, vol.332, pp.1-8, 2016. ,
The reduced space sequential quadratic programming (sqp) method for calculating the worst resonance response of nonlinear systems, J. Sound Vib, vol.425, pp.301-323, 2018. ,
Global resonance optimization analysis of nonlinear mechanical systems: application to the uncertainty quantification problems in rotor dynamics, Commun. Nonlinear Sci. Numer. Simul, vol.19, issue.9, pp.3323-3345, 2014. ,
The harmonic balance method for bifurcation analysis of large-scale nonlinear mechanical systems, Comput. Methods Appl. Mech. Eng, vol.296, pp.18-38, 2015. ,
Bifurcation tracking by harmonic balance method for performance tuning of nonlinear dynamical systems, Mech. Syst. Signal Process, vol.88, pp.445-461, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01402109
Manlab 2.0: an interactive path-following and bifurcation analysis software, 2005. ,
On the response of the non-linear vibration absorber, Int. J. Non-Linear Mech, vol.24, issue.4, pp.281-293, 1989. ,
Nonlinear dynamics of flexible rotating shafts with centrifugal pendulum vibration absorbers, ASME 2015 International Design Engineering Technical Conferences and Computers and Information in Engineering Conference, pp.8-13, 2015. ,
, Mechanical Vibrations: Theory and Applications to Structural Dynamics, 1997.
Analysis of the characteristics of pseudo-resonance and anti-resonance, J. Vib. Acoust, vol.118, issue.4, pp.663-667, 1996. ,
On the significance of antiresonance frequencies in experimental structural analysis, J. Sound Vib, vol.219, issue.3, pp.379-394, 1999. ,
Erzwungene Schwingungen bei veränderlicher Eigenfrequenz und ihre technische Bedeutung, no. 41-42, R, 1918. ,
A harmonic-based method for computing the stability of periodic solutions of dynamical systems, Comptes Rendus Mécanique, vol.338, issue.9, pp.510-517, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-01452004
A high order purely frequency-based harmonic balance formulation for continuation of periodic solutions, J. Sound Vib, vol.324, issue.12, pp.243-262, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00315288
, Practical Bifurcation and Stability Analysis, vol.5, 2010.
DOI : 10.1007/978-1-4419-1740-9
, Numerical Methods for Bifurcations of Dynamical Equilibria, 2000.
Determination of branches of limit points by an asymptotic numerical method, European Congress on Computational Methods in Applied Sciences and Engineering ,
URL : https://hal.archives-ouvertes.fr/hal-00623437
, Numerical Recipes 3rd Edition: The Art of Scientific Computing, 2007.
, Differential Geometry of Curves and Surfaces, 1976.
The Pendulum: A Case Study in Physics, 2009. ,
A high-order, purely frequency based harmonic balance formulation for continuation of periodic solutions: the case of non-polynomial nonlinearities, J. Sound Vib, vol.332, issue.4, pp.968-977, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00758184
