A macroscopic traffic flow model accounting for bounded acceleration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
This paper details a new macroscopic traffic flow model accounting for the boundedness of traffic acceleration, which is required for physical realism. Our approach relies on the coupling between a scalar conservation law, which refers to the seminal LWR model, and a system of Ordinary Differential Equations describing the trajectory of accelerating vehicles, which we treat as moving constraints. We propose a Wave Front Tracking Algorithm to construct approximate solutions. We use this algorithm to prove the existence of solutions to the associated Cauchy Problem, and provide some numerical examples illustrating the solution behaviour.
Laurent-Brouty_Costeseque_Goatin-2019.pdf (748.84 Ko) Télécharger le fichier
hal-02155131 , version 1 (13-06-2019)
hal-02155131 , version 2 (18-12-2019)
hal-02155131 , version 3 (22-02-2020)
hal-02155131 , version 4 (26-11-2020)
  • HAL Id : hal-02155131 , version 1
Nicolas Laurent-Brouty, Guillaume Costeseque, Paola Goatin. A macroscopic traffic flow model accounting for bounded acceleration. 2019. ⟨hal-02155131v1⟩
391 Consultations
420 Téléchargements
