Conference papers
Efficient Estimation of the Mean Hitting Time to a Set of a Regenerative System
Marvin K Nakayama 1 Bruno Tuffin 2
2 DIONYSOS - Dependability Interoperability and perfOrmance aNalYsiS Of networkS
Inria Rennes – Bretagne Atlantique , IRISA-D2 - RÉSEAUX, TÉLÉCOMMUNICATION ET SERVICES
Abstract : We consider using simulation to estimate the mean hitting time to a set of states in a regenerative process. A classical simulation estimator is based on a ratio representation of the mean hitting time, using crude simulation to estimate the numerator and importance sampling to handle the denominator , which corresponds to a rare event. But the estimator of the numerator can be inefficient when paths to the set are very long. We thus introduce a new estimator that expresses the numerator as a sum of two terms to be estimated separately. We provide theoretical analysis of a simple example showing that the new estimator can have much better behavior than the classical estimator. Numerical results further illustrate this.
Document type :
Conference papers
Complete list of metadata
Cited literature [13 references]  Display  Hide  Download
https://hal.inria.fr/hal-02155409
Contributor : Bruno Tuffin Connect in order to contact the contributor
Submitted on : Thursday, June 13, 2019 - 3:26:16 PM
Last modification on : Friday, August 5, 2022 - 2:54:52 PM
File
wsc19-newmttf-HAL.pdf
Identifiers
  • HAL Id : hal-02155409, version 1
Citation
Marvin K Nakayama, Bruno Tuffin. Efficient Estimation of the Mean Hitting Time to a Set of a Regenerative System. WSC 2019 - Winter Simulation Conference, Dec 2019, National Harbor, United States. pp.1-14. ⟨hal-02155409⟩
Share
Metrics
Record views
62
Files downloads
86
