Efficient Monte Carlo methods for estimating failure probabilities, Reliability Engineering and System Safety, vol.165, pp.376-394, 2017. ,
DOI : 10.1016/j.ress.2017.04.001
Correlation-induction techniques for estimating quantiles in simulation, Operations Research, vol.46, pp.574-591, 1998. ,
DOI : 10.1145/224401.224614
URL : http://repository.lib.ncsu.edu/bitstream/1840.4/4541/1/1995_0038.pdf
A note on quantiles in large samples, Annals of Mathematical Statistics, vol.37, issue.3, pp.577-580, 1966. ,
DOI : 10.1214/aoms/1177699450
URL : https://doi.org/10.1214/aoms/1177699450
Probability and Measure, 1995. ,
On a simple estimate of the reciprocal of the density function, Annals of Mathematical Statistics, vol.39, pp.1083-1085, 1968. ,
Confidence intervals for quantiles when applying variance-reduction techniques, ACM Transactions On Modeling and Computer Simulation, vol.22, issue.2, 2012. ,
DOI : 10.1145/2133390.2133394
Randomization of number theoretic methods for multiple integration, SIAM Journal on Numerical Analysis, vol.13, issue.6, pp.904-914, 1976. ,
Application of risk informed safety margin characterization to extended power uprate analysis, Reliability Engineering and System Safety, vol.129, pp.19-28, 2014. ,
Convergence of randomized quasi-Monte Carlo sampling for value-at-risk and conditional value-atrisk, 2017. ,
Reclaiming quasi-Monte Carlo efficiency in portfolio value-at-risk simulation through Fourier transform, Management Science, vol.52, issue.6, pp.925-938, 2006. ,
DOI : 10.1287/mnsc.1060.0505
Value at Risk: The New Benchmark for Managing Financial Risk, 2007. ,
Application of quasi-monte carlo methods to elliptic PDEs with random diffusion coefficients -a survey of analysis and implementation, Foundations of Computational Mathematics, vol.16, issue.6, pp.1631-1696, 2016. ,
Simulation of nonlinear portfolio value-at-risk by monte carlo and quasi-monte carlo methods, Financial Engineering and Applications, 2006. ,
On the distribution of integration error by randomly-shifted lattice rules, Electronic Journal of Statistics, vol.4, pp.950-993, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00793293
Monte Carlo and Quasi-Monte Carlo Sampling. Series in Statistics, 2009. ,
Selection criteria for lattice rules and other low-discrepancy point sets, Mathematics and Computers in Simulation, vol.55, issue.1-3, pp.139-148, 2001. ,
DOI : 10.1016/s0378-4754(00)00254-8
On the asymptotic distribution of scrambled net quadrature, Annals of Statistics, vol.31, issue.4, pp.1282-1324, 2003. ,
Estimating a failure probability using a combination of variance-reduction tecniques, Proceedings of the 2015 Winter Simulation Conference, pp.621-632, 2015. ,
Random Number Generation and Quasi-Monte Carlo Methods, vol.63, 1992. ,
Randomly permuted (t,m,s)-nets and (t,s)-sequences, Monte Carlo and Quasi-Monte Carlo Methods in Scientific Computing: Lecture Notes in Statistics, vol.106, pp.299-317, 1995. ,
DOI : 10.1007/978-1-4612-2552-2_19
Monte Carlo variance of scrambled net quadrature, SIAM Journal of Numerical Analysis, vol.34, pp.1884-1910, 1997. ,
Scrambled net variance for integrals of smooth functions, Annals of Statistics, vol.25, issue.4, pp.1541-1562, 1997. ,
Scrambling Sobol' and Niedeerreiter-Xing points, Journal of Complexity, vol.14, issue.4, pp.466-489, 1998. ,
DOI : 10.1006/jcom.1998.0487
URL : https://doi.org/10.1006/jcom.1998.0487
Deterministic simulation for risk management, Journal of Portfolio Management, vol.25, issue.5, pp.122-127, 1999. ,
DOI : 10.3905/jpm.1999.319698
Approximation Theorems of Mathematical Statistics, 1980. ,
Pilot application of risk informed safety margin characterization to a total loss of feedwater event, Reliability Engineering and System Safety, vol.117, pp.65-72, 2013. ,
Lattice Methods for Multiple Integration, 1994. ,
DOI : 10.1016/0377-0427(85)90012-3
URL : https://doi.org/10.1016/0377-0427(85)90012-3
On the use of low discrepancy sequences in Monte Carlo methods, Monte Carlo Methods and Applications, vol.2, issue.4, pp.295-320, 1996. ,
Variance reduction order using good lattice points in Monte Carlo methods, Computing, vol.61, issue.4, pp.371-378, 1998. ,
Randomization of quasi-monte carlo methods for error estimation: Survey and normal approximation, Monte Carlo Methods and Applications, vol.10, issue.3-4, pp.617-628, 2004. ,
Nuclear Regulatory Commission. Final safety evaluation for WCAP-16009-P, revision 0, "realistic large break LOCA evaluation methodology using automated statistical treatment of uncertainty method (AS-TRUM), Nuclear Regulatory Commission, 2005. ,
Nuclear Regulatory Commission. Acceptance criteria for emergency core cooling systems for light-water nuclear power reactors. Title 10, Code of Federal Regulations §50, NRC, vol.46, 2010. ,
Nuclear Regulatory Commission. Applying statistics. U.S. Nuclear Regulatory Commission Report NUREG-1475, 2011. ,
