Fault Heterogeneity and the Connection between Aftershocks and Afterslip - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bulletin of the Seismological Society of America Année : 2019
Whether aftershocks originate directly from the mainshock and surrounding stress environment or from afterslip dynamics is crucial to the understanding of the nature of aftershocks. We build on a classical description of the fault and creeping regions as two blocks connected elastically, subject to different friction laws. We show analytically that, upon introduction of variability in the fault plane’s static friction threshold, a non trivial stick-slip dynamics ensues. In particular we support the hypothesis that the aftershock occurrence rate is proportional to the afterslip rate, up to a corrective factor that is also computed. Thus, the Omori law originates from the afterslip’s logarithmic evolution in the velocity-strengthening region. We confirm these analytical results with numerical simulations, generating synthetic catalogs with statistical features in good agreement with instrumental catalogs. In particular we recover the Gutenberg-Richter law with a realistic b-value (b'1) when Coulomb stress thresholds obey a power law distribution.
2020-BSSA-2018244_AUTHOR_1.pdf (395 Ko) Télécharger le fichier
hal-02156407 , version 1 (17-09-2020)
Eugenio Lippiello, Giuseppe Petrillo, François Landes, Alberto Rosso. Fault Heterogeneity and the Connection between Aftershocks and Afterslip. Bulletin of the Seismological Society of America, 2019, 109 (3), pp.1156-1163. ⟨10.1785/0120180244⟩. ⟨hal-02156407⟩
73 Consultations
336 Téléchargements
