Response of rate-and-state seismogenic faults to harmonic shear-stress perturbations, Geophys. J. Int, vol.198, issue.1, pp.385-413, 2014. ,
Model and theoretical seismicity, Bull. Seismol. Soc. Am, vol.57, pp.341-371, 1967. ,
Seismicity controlled by a frictional afterslip during a small magnitude seismic sequence (M L < 5) on the Chihshang fault, J. Geophys. Res, vol.123, issue.2, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-01856082
Constraints on slow earthquake dynamics from a swarm in central Italy, Phys. Rep, vol.286, issue.5447, pp.1-91, 1999. ,
A constitutive law for rate of earthquake production and its application to earthquake clustering, J. Geophys. Res, vol.99, issue.B2, pp.2601-2618, 1994. ,
Mapping the rheology of the central Chile subduction zone with aftershocks, Geophys. Res. Lett, vol.44, issue.11, pp.5374-5382, 2017. ,
Afterslip (and only afterslip) following the, 2004. ,
, Geophys. Res. Lett, vol.34, issue.6
Relation between stress heterogeneity and aftershock rate in the rate-and-state model, J. Geophys. Res, vol.111, issue.B7304, 2006. ,
, Frictional afterslip following the 2005 Nias-Simeulue earthquake, vol.312, 1921.
URL : https://hal.archives-ouvertes.fr/hal-00407597
Realistic spatial and temporal earthquake distributions in a modified Olami-Feder-Christensen model, Phys. Rev. E, vol.81, p.46117, 2010. ,
A mechanism for spatial and temporal earthquake clustering, J. Geophys. Res, vol.115, issue.B5, p.312, 2010. ,
Viscoelastic effects in avalanche dynamics: A key to earthquake statistics, Phys. Rev. Lett, vol.112, p.174301, 2014. ,
Frictional properties on the San Andreas fault near Parkfield, California, inferred from models of afterslip following the 2004 earthquake, Bull. Seismol. Soc. Am, vol.96, issue.4B, p.321, 2006. ,
Variability of earthquake nucleation in continuum models of rate-and-state faults and implications for aftershock rates, J. Geophys. Res, vol.113, issue.B12, 2007. ,
Scaling laws in earthquake occurrence: Disorder, viscosity, and finite size effects in Olami-Feder-Christensen models, Phys. Rev. E, vol.93, p.51001, 2016. ,
Mechanical origin of aftershocks, Sci. Rep, vol.5, pp.1-6, 2015. ,
Statistical features of foreshocks in instrumental and etas catalogs, Pure Appl. Geophys, vol.174, pp.1679-1697, 2017. ,
On the mechanics of earthquake afterslip, J. Geophys. Res, vol.96, issue.B5, pp.8441-8452, 1991. ,
Space time distribution of afterslip following the 2003 Tokachi-Oki earthquake: Implications for variations in fault zone frictional properties, Geophys. Res. Lett, vol.31, issue.6, 2004. ,
Dynamics of a velocity strengthening fault region: Implications for slow earthquakes and postseismic slip, J. Geophys. Res, vol.113, issue.B9, 2008. ,
Postseismic relaxation driven by brittle creep: A possible mechanism to reconcile geodetic measurements and the decay rate of aftershocks, application to the Chi-Chi earthquake, J. Geophys. Res, vol.109, 2004. ,
Modeling afterslip and aftershocks following the 1992 Landers earthquake, J. Geophys. Res, vol.112, issue.B7, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00324504
Geodetic displacements and aftershocks following the 2001 M w 8:4 Peru earthquake: Implications for the mechanics of the earthquake cycle along subduction zones, J. Geophys. Res, vol.110, issue.B9, 2005. ,
A model of aftershock migration driven by afterslip, Geophys. Res. Lett, vol.45, issue.5, pp.2283-2293, 2018. ,
Slip complexity in earthquake fault models, Proc. Natl. Acad. Unit. States Am, vol.93, pp.3811-3818, 1996. ,
Calculation of aftershock accumulation from observed postseismic deformation: M6, Geophys. Res. Lett, vol.37, issue.13, 2004. ,
Postearthquake relaxation after the 2004 M6 Parkfield, California, earthquake and rate-and-state friction, J. Geophys. Res, vol.113, issue.B10, 2008. ,
Postearthquake relaxation and aftershock accumulation linearly related after the, vol.6, 2003. ,
, Bull. Seismol. Soc. Am, vol.97, issue.5, p.1632
, The Mechanics of Earthquakes and Faulting, 2002.
, SSA style requires that author names are not abbreviated. Please provide the full name of all authors
, Please note that part labels have been inserted to Figure 1. Kindly check and correct if necessary
, Because the figures will only appear in color online, and the text will be the same both online and in print, references to specific colors must be removed throughout the figure captions. Please provide revised wording and/or revised figures as needed
