Causal Markov mesh hierarchical modeling for the contextual classification of multiresolution satellite images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we address the problem of the joint classifica-tion of multiple images acquired on the same scene at different spatial resolutions. From an application viewpoint, thisproblem is of importance in several contexts, including, mostremarkably, satellite and aerial imagery. From a methodolog-ical perspective, we use a probabilistic graphical approachand adopt a hierarchical Markov mesh framework that we have recently developed and models the spatial-contextual classification of multiresolution and possibly multisensor images. Here, we focus on the methodological properties of this framework. First, we prove the causality of the model, a highly desirable property with respect to the computationa lcost of the inference. Then, we prove the expression of the marginal posterior mode criterion for this model and discuss the related assumptions. Experimental results with multi-spectral and panchromatic satellite images are also presented.
icipAle.pdf (391.16 Ko) Télécharger le fichier
hal-02157081 , version 1 (15-06-2019)
  • HAL Id : hal-02157081 , version 1
Alessandro Montaldo, Luca Fronda, Ihsen Hedhli, Gabriele Moser, Sebastiano B. Serpico, et al.. Causal Markov mesh hierarchical modeling for the contextual classification of multiresolution satellite images. ICIP 2019 - IEEE International Conference on Image Processing, Sep 2019, Taipei, Taiwan. ⟨hal-02157081⟩
Collections
INRIA INRIA2
124 Consultations
213 Téléchargements
