Fast Public Transit Routing with Unrestricted Walking through Hub Labeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a novel technique for answering routing queries in public transportation networks that allows unrestricted walking. We consider several types of queries: earliest arrival time, Pareto-optimal journeys regarding arrival time, number of transfers and walking time, and profile, i.e. finding all Pareto-optimal journeys regarding travel time and arrival time in a given time interval. Our techniques uses hub labeling to represent unlimited foot transfers and can be adapted to both classical algorithms RAPTOR and CSA. We obtain significant speedup compared to the state-of-the-art approach based on contraction hierarchies.
arxiv.pdf (159.1 Ko) Télécharger le fichier
hal-02161283 , version 1 (20-06-2019)
Duc-Minh Phan, Laurent Viennot. Fast Public Transit Routing with Unrestricted Walking through Hub Labeling. Special Event on Analysis of Experimental Algorithms (SEA2), Jun 2019, Kalamata, Greece. ⟨hal-02161283⟩
91 Consultations
420 Téléchargements
