Reports
Causality Analysis and Fault Ascription in Component-Based Systems
Gregor Gössler 1 Jean-Bernard Stefani 1
1 SPADES - Sound Programming of Adaptive Dependable Embedded Systems
Inria Grenoble - Rhône-Alpes, LIG - Laboratoire d'Informatique de Grenoble
Abstract : This article introduces a general framework for fault ascription, which consists in identifying, within a multi-component system, the components whose faulty behavior has caused the failure of said system. Our framework uses configuration structures as a general semantical model to handle truly concurrent executions, partial and distributed observations in a uniform way. We define a set of expected properties for counterfactual analysis, and present a refined analysis that conforms to our requirements. This contrasts with current practice of evaluating definitions of counterfactual causality a posteriori on a set of toy examples. As an early study of the behavior of our analysis under abstraction we establish its monotony under refinement.
Complete list of metadata
Cited literature [39 references]  Display  Hide  Download
https://hal.inria.fr/hal-02161534
Contributor : Gregor Gössler Connect in order to contact the contributor
Submitted on : Tuesday, August 25, 2020 - 10:33:25 AM
Last modification on : Wednesday, July 6, 2022 - 4:14:52 AM
File
RR-9279.pdf
Identifiers
  • HAL Id : hal-02161534, version 3
Citation
Gregor Gössler, Jean-Bernard Stefani. Causality Analysis and Fault Ascription in Component-Based Systems. [Research Report] RR-9279, Inria - Research Centre Grenoble – Rhône-Alpes. 2019, pp.1-28. ⟨hal-02161534v3⟩
Share
Metrics
Record views
174
Files downloads
339
